Threads: 167
As far as I can tell, the hook at the end of the elastics hook onto the seat back hinges.
Usually, I poke the large legs into the side plugs
Hook the straps behind the hinges (make sure they are out of the way enough to put the seat backs in place)
tighten the big legs up until it holds together
Put the seat backs into place
put the little legs in the crack left by the the seat backs
Tighten the large legs
I have no idea if I'm 100% correct, but it seems to work...2 years and I'm still not certain.
Worst instructions ever from Porsche....
Best of Luck,
jay
Threads: 65
One word of warning: though it appears that you can raise and lower the top with the deflector in place, DON'T!!!! If you install the deflector, you will be able to put the top up without removing the deflector, but if you then lower the top again, with the deflector in place, it will lower, BUT, it will be jammed against the deflector on the sides, which you will not notice initially. This may result in little rips to the top, especially if your top is worn. This happened to me on the way back from the Paso Robles event last April. It cost me almost $2K for the new top. <img src="/forum/images/smilies/968/ohmy.gif" class="smilie" alt="" />
Bill
'93 Horizon Blue Metallic Cab
'58 Triumph TR3A (sold)
'06 Lexus RX400h Hybrid
Lots of guitars
