Over the past 7 plus years of owning the blue car, I have had no less than a dozen alignments. Some of them were good. Some of them not so much. as many have experienced, the machines were sometimes not calibrated, resulting in a "garbage in - garbage out" situation. Other times the tech just plain didn't know what he was doing. I've spent anywhere from $140 to $360 on these things, with price not seeming to make any difference in result.
Finally I found a guy who both knows what he is doing, and has accurate gear. On top of that, he was the easiest guy I think I've ever worked with.
I went in telling him what had been done, and what I was seeking. The first words out of his mouth were "Has the car been corner balanced?" Immediately I knew that I had at least found somebody who knew what he was doing. We then talked about the car, and I queried him as to his knowledge of the tools and such. He got all of those right. So, I scheduled what was to be yet another alignment appointment, including a corner balance.
I had been messing around with this car so much, and setting and resetting the ride height and such, that I had pretty much mangled my corners. It was time to get it corner balanced. He spend about an hour and a half on that, and in the end, i was within 5-10lbs at each corner, but more importantly i was criss cross and left to right perfect. YeeHa!
Then it was off to the alignment portion. I had been trying to reduce my rear negative camber, since I have bigger swaybars, and all the braces, and consequently no longer need so much. I had been having continual issues with this, essentially being unable to get below -2 degrees. This left the outside edge of the tire in the air. Not good.
After about 45 minutes of up and down and playing with it, he nailed it exactly at the -1.6 degrees that I wanted. After that, the front was easy.
When all was said and done, I finally had the predictable balance that I wanted, with the angles I wanted.
Time to drive.
I HIGHLY recommend this guy.
His name is Darrin, and the shop is West End Alignment on Vermont Ave in Gardena.
Cost is $250. Cash or Check only. Don't even think about quibbling though. The price is what it is, and he knows that it's worth every penny. Expect at least a week lag before you can get in.
