Battery location on race car
Hi everyone,
I am thinking of moving the battery from inside the rear wing at the back to the passenger seat location in the compartment for ease of access and weight distribution (to act as a counterweight to big Graham!)
Anybody else moved there battery to anohter location?
Is it safe?
What about weight distribution?
I am new to this so any advice will be appreciated.
There do not seem to be any rules in the MSA blue book about not being able to do this?
<img src="/forum/images/smilies/968/biggrin.gif" class="smilie" alt="" />
Graham
if you are running a right hand road race circuit, i would put it in the rear most right corner
if you are running a left hand road race circuit, i would put it in the rear most left hand corner
if you are runing autocross, i would try to get it as far to the center of the car as possible, but my second choice would be opposite the driver in the rear most corner
What time is it over there?
It's only 11.18 here!?!
It is in the rear most corner opposite the driver already
Circuits will change I think
Is it not better further forward though opposite me?
Graham
lol - yeah - can't sleep
the idea is to get the centrifugal force to work for you, or more to the point the centripital force to help - your weight is going to push the car in one direction, gravity is going to push it in another, the battery only weighs 40lbs - it will make the most difference in the corner - it will also help in weight transfer under braking
i've been considering moving my battery to the rear for exactly this reason - ours are in the front over here
Ahh...
my car is a CS so thats why it's there.
makes sense now
I think I will leave it where it is
Graham
Does your car have the tray in the rear wheel arch or is that a CS trait as well?
Graham
no - if you have a shot of that, or the part number, that would be great - i'd hate to reinvent the wheel
Graham,
Just get a lightweight battery and then it won't make a huge difference where it is. I'm running a Odyssey PC680 in the stock location. It is 20lbs lighter.
http://www.odysseybatteries.com/battery/pc680mjt.htm
You can usually find them new on ebay for a good price.
Eric
Thats not a bad idea Eric.
That is probably the way to go.
Flash,
I can understand why they put it where they did in the CS then.
I'll take a picture for you Flash
I may remove the battery tray anyway as I need to access the wheel arch to clean it up for painting.
To be honest, The CS seems to have quite a few add on differances.
Graham
let me be the first to express interest in purchasing it from you
Eric,
That's a great looking battery!
Does it hold a charge and work well?
How long do they last...2-3 years?
Jason
The battery has worked great so far. I put it in last winter. The car has started strongly everytime. I always turn off my kill switch between sessions so it has zero drain.
Eric
If I don't have a kill switch and just use turn off the car from the ignition switch is it the same...or, are there things still pulling on the battery?
Jason
I can't imagine you would have much draw since you have removed a lot of things. I do the kill switch because I want to be sure. I have forgotten the switch sometimes and it still starts fine. I would be most concerned about the layoff times between events. Disconnecting or a battery tender would be a good idea.
Eric
Thanks,
Sounds like an easy, and inexpensive, way to lose 20 lbs.
Jason
a kill switch is mandatory in scca - i'm surprised it isn't in pca - gotta check that one
if the ground is good, and you've removed the clock, radio, alarm, and interior lighting, then i can't think of anything else that would draw on the battery while off, but i agree that either a kill switch or a tender is the sure way
Eric,
Is your battery in the engine compartment then or in the cabin?
Graham
The battery is in the engine compartment for us ClubSport deprived folks. I was too lazy to even attempt changing the wiring to move it somewhere else.
A kill switch is required for PCA racing but not driver education events - which Jason has been doing.
Eric
ah - i thought he was setting up a race car
Last Post by Velocity
10-21-2021, 06:54 PM
Last Post by Qfrank
11-05-2013, 10:44 PM
Last Post by cosimo
05-10-2012, 04:47 PM
