09-04-2017, 07:41 PM
Only after about 10 minutes of driving the battery cables' connections ( tne end pieces which go on the battery terminals posts ) get EXTREMELY hot ! So hot, that if you touch them they'll singe the skin on your fingers . The battery ( which is only about a year old ) when cold , reads about 12.3 V , and when the engine is running the charge coming in seems to be about 12.5 - 12.6 , but not sure what's happening , and why the cable ends are as hot as they are . And the battery has been very sluggish when starting the car after three or four days of sitting, so I'm wondering if by some chance the alternator is overcharging and frying the battery ? Is that ( excessive AMPS output while the voltage stays at a normal level ) , even a technical possibility ? I don't have an amp meter only voltage one , and I have no clue about these things anyway so just trying to figure out what's going on .. We've had 102 - 106 mid day temps temps here for an entire week so I'm sure that did not help matters with starting , but it does not explain what's causing the cable connections to get as hot as to burn your hands if you touch them.
(This post was last modified: 09-04-2017, 07:43 PM by ds968.)
