sandoval - did you see my post about this issue? It could also be that the web server that's hosting your site doesn't have it's mime types configured correctly.
[quote name='Etnier' date='May 30 2006, 05:56 PM']Thanks indeed! Will this repair the "View Vehicles" bug?
Eric: we sure appreciate the dedication you've shown to making this a productive and useful information source.  <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
[right][post="22081"]<{POST_SNAPBACK}>[/post][/right][/quote]
Is this the View vehicles bug? I get this everytime I click on View. Attachments to threads work fine for me but Im using IE.
The file /home/flash/public_html/sources/lib/garage_loader.php has been encoded with the ionCube PHP Encoder and requires the free ioncube_loader_lin_4.4.so ionCube PHP Loader to be installed.
[quote name='smshirk' date='May 31 2006, 09:03 AM']Is this the View vehicles bug? I get this everytime I click on View...
[right][post="22127"]<{POST_SNAPBACK}>[/post][/right][/quote]
That's it. It was very nice to be able to see what was up with a poster's vehicle directly from the post.
ok - so how exactly does one fix this?
Well the error message seems to indicate that a software component in the forum platform is missing: maybe a software upgrade required upgraded support for the "view vehicles" function, for example.
This has been under discussion for a while...
ok - i thought by your last post, that it had been fixed, or that i needed to do something - so, it is still not any better then - i know i still can't open anything here
Flash: it's hard to tell from your last two posts here. Are you clear on the fact that we're now discussing two distinct issues?
• The "attached images" bug.
• In the posts immediately preceding this one, discussion turned to the "View Vehicles" bug.
ah - i see that now - went to the site - doesn't work
Eric,
Are you any closer to finding a solution on the attached pic issue....?
I have tried to view attached images on 6 different browsers and it all comes up with the same php parsing code. Anyone have a solution to this yet? <img src="/forum/images/smilies/968/sad.gif" class="smilie" alt="" />
I have a temporary solution for now.
Just right-mouse click and choose 'save-as' it will ask you to save it as a .php file, but just rename it to "whatever.jpg"
Works for me. Is it churlish to point out that the images then have to be opened in a seperate application? <img src="/forum/images/smilies/968/biggrin.gif" class="smilie" alt="" />
They have a fix but the board skins might not load correctly. So I need to do this when I have some extra time to fix things that might not migrate over to the new software. I will try and get to this, this weekend.
"right" click? is there a wrong click?
[quote name='flash' date='Jun 8 2006, 10:36 AM']"right" click?  is there a wrong click?
[right][post="22523"]<{POST_SNAPBACK}>[/post][/right][/quote]
ba-dum-ching!!
stick around folks, there's another show at 11
[quote name='SANDOVAL' date='Jun 7 2006, 10:21 PM']They have a fix  but the board skins might not load correctly. So I need to do this when I have some extra time to fix things that might not migrate over to the new software. I will try and get to this, this weekend.
[right][post="22498"]<{POST_SNAPBACK}>[/post][/right][/quote]
Eric: I hate to be a pain, but it's a month now. I miss them photos!
<img src="/forum/images/smilies/968/sad.gif" class="smilie" alt="" /> <img src="/forum/images/smilies/968/sad.gif" class="smilie" alt="" /> <img src="/forum/images/smilies/968/sad.gif" class="smilie" alt="" />
Thanks....
In the continuing absence of w3c compliance I found another simple way to see the pics with Firefox without downgrading to IE.
And then I saw Chris told us the same <img src="/forum/images/smilies/968/tongue.gif" class="smilie" alt="" />
<delete>
Now we need a fix to the Garage entry, although there is a Linux port I'm not installing funny extensions.
With greatest respect for what you're trying to do, it doesn't seem to be constructive call this a "simple" "fix":
• Right-click
• Save the file
• Go to the file
• Change the filename
• Open in an another program
The whole purpose of this thumbnailing and onsite hosting of images was to make them readily available to forum members. Have you tried that 'fix' when someone posts 5-10 images of his new car, camshaft wear or whatever?
This has gone unaddressed since May: I have to assume that the forum has gone Windows-only, IE-only. I don't visit here very often.
[quote name='Etnier' date='Aug 14 2006, 08:12 AM']With greatest respect for what you're trying to do, it doesn't seem to be constructive call this a "simple" "fix":
• Right-click
• Save the file
• Go to the file
[right][post="25252"]<{POST_SNAPBACK}>[/post][/right][/quote]
I fully admitted in my post that it was a "temporary solution"..
I'm still using firefox, and sometimes I don't even bother looking at pics because of the steps involved <img src="/forum/images/smilies/968/sad.gif" class="smilie" alt="" />
