Full Version: Motor mounts
Greetings,
I need to change my motor mounts and know that there are at least four different manufacturers that carry the part.
Meyle
Coreteco (OEM most expensive)
Rein Automotive
Uro (cheapest)
I was looking for input as to what is the best one. Also, has anyone had an experience with any of these manufacturers. Thanks!
Go with the meyle if you don't want sting for the oem mounts.
Did you try sunset for pricing on oem?
flwbyu,
I've tried to go with "lesser" mounts, only to be disappointed. Headlights rattled, front ends seemed like it would shake loose, especially in cold weather. "Cheap always ends up being expensive." is what comes to mind here, but I know for sure that even the "lesser" mounts are not cheap by any stretch. IMHO, from experience, go with OEM and you won't have to do the job twice. Just bite the bullet. We all have to do it.
I am not sure what make you need, or even what make is in my car, only that I have OEM and no more shake, rattle, and roll. I recommend that you contact RS Barn. They have lot's of experience in these matters. Lots!
Best of luck!
-Scott
I am probably going to go with the OEM (Coreteco) motor mounts which are around $210 each ($420 pair). I agree with everyone, better to do it right the first time around. I just thought I would get a feel for what was out there and if anything was better or worse. I appreciate all the comments! Thanks.
sorry - i'm not done with the new mounts yet - been a bit busy huffing and puffing
Pretty sure it would be the same as the 944s2. Can be found a hair under 200. Better than 210.
http://944online.com/cgi-bin/ASI_Store.cgi...gineblock-944s2
http://944online.com/cgi-bin/ASI_Store.cgi...+skukey_1001105
http://www.pelicanparts.com/catalog/shopca..._pg4.htm#item19
I see your local....Dont have any extra mounts in the garage, on the shelf. Got a couple that were brand new when the car was hit. Maybe 200 miles. They need to be removed still.
Check with one of the Porsche dealers that discounts parts. I just checked on mounts and they are $157 a piece from Porsche.
I have used the inexpensive mounts a couple times on my S2s with no problems, but I did not take note of the manufacturer. I got one set from Zims and the other from some random internet parts supplier years ago.
About time for most if not all of us.
Group buy?
Jeff at Sunset?
Comments?
P.S. Odometer hits 200K miles next week.
210 bucks per mount?! Wow! It's been about three years since I replaced mine, but I seem to remember paying about $95 apiece for OEM's from Sunset.
