12-21-2005, 04:30 PM
Hi Everyone!
As detailed in my previous post, I have recently replaced my clutch at home with success, but am having some difficulty <img src="/forum/images/smilies/968/mad.gif" class="smilie" alt="" /> getting an acceptable result regarding the bleeding of the hydraulic clutch system.
I have a power bleeder that I use, and first bled the air out of the slave cylinder at the clutch housing.
Getting a clutch that let out pretty much at the end of the pedal travel I ran another 1/2 liter of fluid through the system, pumping the pedal as I went, and found a couple of additional bubbles. The result was better, but not what I had hoped for.
On my 951 I would usually get an additional bubble out of the line at the firewall, where the line has a fitting as it passes through the firewall just under the hood and adjacent to the fuse and relay box. I tried this location as well, but can't seem to chase out any more air.
Does anyone have experience with the bleeding procedure for the 968's? Any help would be appreciated!
Lance
Lance
