Full Version: looking for rs engineering
ok - i'm obviously internet lame - i can't find contact info on rs engineering in torrance - time to do the injectors
help please
That's because it's probably RC Engineering found with search term "injector cleaning" torrance
<img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
doh!
yup - that'll do it - thanks
They just did mine last week.
Pre-cleaning numbers:
275 Good
279 Good
281 Good
270 Dripping
Post cleaning numbers:
284 Excellent
285 Excellent
286 Excellent
284 Excellent
System balance went from 4.7% to a tidy 0.7%
Pretty happy with those results, that's GOT to be worth a few BHP....and certainly some smoothness.
-Mirror
[quote name='flash' date='May 1 2006, 06:23 PM']doh!
[right][post="20224"]<{POST_SNAPBACK}>[/post][/right][/quote]
dropping mine off today - thanks - doing the whole "major tune up" thing
What do they typically charge for this service..?
If I remember correctly, somewhere in the ballpark of $120-130, not including removal of course.
[quote name='S_Cal968' date='May 2 2006, 01:10 PM']What do they typically charge for this service..?
[right][post="20289"]<{POST_SNAPBACK}>[/post][/right][/quote]
I've heard good things about Marren Injection....
http://www.injector.com/injectorservice.php
I'm probably going to send mine out to them pretty soon.
They do seem to be the good east coast resource. I've heard the same.
[quote name='mitch968' date='May 2 2006, 02:04 PM']I've heard good things about Marren Injection....
[right][post="20296"]<{POST_SNAPBACK}>[/post][/right][/quote]
rc is $24 each - typically one day turnaround - dropped off today - i should be picking them up tomorrow
Bob: how many miles on your car now and did they look carboned up?
43k
didn't look bad - the age was the major motivation - sitting as much as it has leads to varnish - this was further indicated by the failure on the bleed down test - it is supposed to hold 2 bar of pressure at 20 minutes - didn't get close
injector #1 before 287cc after 291cc
injector #2 before 284cc after 290cc
injector #3 before 271cc after 289cc
injector #4 before 281cc after 290cc
looks like #3 was the goofy one causing me the "problem"
good to go now - should run very nicely with these, a new hotter coil, 8mm wires, rotor, cap, O2 sensor, and another set of the iridium plugs
installing A/F guage at the same time, so i can dial mixture in according to altitude
I have nearly double that mileage, so I'm looking forward to a noticeable improvement after I have mine cleaned.
Bob: don't let the smog tech see anything that changes the a/f mix... <img src="/forum/images/smilies/968/wink.gif" class="smilie" alt="" />
no worries - this is just a cleaning and reset to factory spec on the injectors - no mod - everything else is transparent and legal
the mixture thing won't be an issue - there is no preclusion from adjustment capability
