Full Version: No start! No spark coming from Ignition Coil!
Hello my name is Sergio and im a proud owner of a 1994 968, but i need your guys help with problems with no spark coming from the ignition coil,
Symptons are:
I replaced the DME relay - looks good
I have fuel being pump into the cilnders
The engine turns healthy
No imobilizer from alarm system
I have healthy bat power coming into the Black wire to the coil +15
All grounds seem ok
Rev limiter bounces when cranking
Changed Coil, but both coils get very hot after a while, even when not cranking the engine.
but still no spark.
Can you help me?
cheers
Typically heat is cause by a short, higher voltage or reversed wiring. This may be a long-shot, but check your connections. The Black wire should be on terminal 15 and the Green on term. 1. The 15v to the coil seems high[??]. If you were to take it to a repair shop, they'd probably try a known-good DME.
Have you attempted to retrieve the trouble codes..? This may display an issue with the DME.
It might be well to check the reference sensor.
Best,
WA
[quote name='w.a.' date='May 30 2006, 08:21 PM']It might be well to check the reference sensor.
Best,
WA
[right][post="22099"]<{POST_SNAPBACK}>[/post][/right][/quote]
Agreed!
