Full Version: Correct offset for a 9 inch wheel
Does anyone know what the correct offset should be for a 16 inch x 9 inch wide wheel? Mine says 9/70 on the wheel near the valve stem but it seems to sit too far inboard. In know that the correct offset for an 7 inch wheel is 55 m and for an 8 inch wheel is 52 mm.
If it is about 45-50 mm what do you think about adding a 20 mm bolt-up spacer to move the wheels out a bit?
a 20mm spacer will absolutely REQUIRE replacing the studs with longer ones, unless you get the bolt-on type
this will also add a significant amount of weight to the wheel, and will require balancing independent of the wheel, unless you get the bolt on type (which adds even more weight)
[attachment=2216][attachment=2215][attachment=2575:attachm
ent][ATTACHMENT NOT FOUND]Bought spacers last week from paragon - they were delivered today. Got the 28 mm spacers with independent bolts. Before and after pics attached. may be only my imagination but car is now quiter in back end.
