06-03-2006, 05:52 PM
Help!!! Has anyone experienced this problem? I did do a search but found nothing. The headlights (both) on my '92 Coupe are stuck in the up position. It seems like they are stuck in mid cycle of the motors because I cannot push them down (as I have done in the past). The lights work and I can crank them down manually but they will not retract when turned off. I did clean all of the ground points this past winter. Could it be a defective headlight switch? Any help or suggestions would be appreciated.
Carl
Carl
