Full Version: Solid Trans Mount?
Does anyone make a solid transaxle mount for the 968 01E unit? I had a Kokeln piece back when I was 5 speed but have been unable to locate someone who has already created a 968 unit. Worst case I can get them CNC'd for me (and a few spares to offset the cost), but if there is already one on the market I'll just purchase that. Thanks!
Mike,
This is on Ebay. Not solid, but maybe worth a look.
Porsche 944 968 Transmission Mount (Race Version)
Item number: 130183213149
# DPS Motorsports is proud to present this new SUPER TRANSMISSION MOUNT
# Fits Porsche 944 1985.5 to 1991 all models, and 968's 1992-1995.
# We are the wholesale distributor for this non-solid aftermarket transmount mount system specifically developed for these Porsches.
# Durable Elastomeric Inserts
# Limits drive train movement
# No metal to metal contact
# Absolutely the last transmission mount you will ever need!
# Call our Porsche parts warehouse toll free with any questions 877-550-8555
# Or email us sales@dps-motorsports.com
[quote name='SILVY968' post='44623' date='Dec 14 2007, 01:09 AM']Mike,
Item number: 130183213149[/quote]
I linked the auction for you. That should make it easier to access.
i had this conversation with pete - we are opting to do better motor mounts at this time, to alleviate the transmission movement - the solid mount out there transmits WAY too much vibration for street use
i will be at the shop today and try to prod my memory on who made the solid mount
The mount that was linked to does not fit the 968
I bought several for guys over here in the UK. 1 x of us has an S2 so his will fit. Mine was modified to make it fit, but i am not happy with it. The bushes have a collar inserted in them that goes through the top plate of the mount, with a bush either side. Where it bolts upto the cross member it tightens fully on the collar, therefore effectively making it a solid mount. Has only been on the car for a few hundred miles plus 2 trackdays - does make a considerable difference. i am quite sure there used to be a pendulum effect from the rear box coming out of chicanes etc. The car does feel better for the stiffer fixing.
However, i'm not happy with the solid fixing of the DPS one, i personally think the bracket is great but the mount to the cross member is somewhat ill-conceived. I intended to obtain a large piece of polybush and come up with something that simply replaced the rubber bush ont he standard mount (it is marginally more complicated than that though)
This is a picture of the mod i made to the mount (by the way the guy selling them was mailed by a couple of us re them not fitting the 968, but never replied!)
To fit it two additional holes had to be drilled in the cross member, some of one of the webs had to be removed, 2x plates made up to extend the mount so that an S2 gearbox mount could be used instead of the 968 one.
Flash,
Are you working on "up-dated" engine mounts? I`am planning to renew my mounts but if you are working on better mounts I will wait untill they are ready...
regards,
Rutger
Thanks guys, but unfortunately none of those are what I'm looking for. I also had a Kokeln solid mount on my street car and didnt find it transmitted to much noise. (and I have Lindsey solid engine mounts)..... granted the car also had a 6 puck spec clutch. Looks like I'll be making a limited run of trans mounts I suspect.
Mike, I could be interested in some if that might help you offset costs? I'm not sure if I'm going to the 6 speed or having a custom tranny made though. Should know by January. If you need commitment before then let me know.
Patrick
yes, i am working on updated engine mounts - i should actually be able to test a prototype between the holidays
Patrick, I'll keep in touch, you'll have to contact me via email though, I'm not longer on rennlist.
[quote name='flash' post='44829' date='Dec 20 2007, 08:01 AM']yes, i am working on updated engine mounts - i should actually be able to test a prototype between the holidays[/quote]
Aaack! I recently replaced mine. I guess the motto here is to never do anything to this car, bacause Flash is probably working on a better version of whatever you're thinking of replacing <img src="/forum/images/smilies/968/huh.gif" class="smilie" alt="" /> Oh, well, at least my DMF looks like it will hold up long enough for the spring centered clutch disk to become available <img src="/forum/images/smilies/968/biggrin.gif" class="smilie" alt="" />
*shrug*
I have Lindsey ultra mounts, used to have super mounts, plenty happy with them.
Guest
Mike, I might be interested if you do a run of tranny mounts. I'll PM you my email, I'm not on here frequently.
my car is still up in the air - i've been so busy finishing off the new car, i only today got to install my new struts, springs and strut mounts
if all goes right, and i finally finish the new car on thursday morning, i will be on the motor mount test late this week
"my car is still up in the air..."
and the sun will come up tomorrow.
(Sorry, Bob, couldn't resist. How are the interior mods coming?)
lol - haven't gotten to my own interior yet - been working on finishing off the new car - once i get mine back on the ground, and the other car out of here, i can actually move mine over to the service bay and swing the doors open to play with it
this wouldn't be so bad if i wasn't also trying to keep the bmw inside and clean - i just had it detailed, and we are selling it - of course i chose to do that the day before a huge storm (by california standards of course)
Hi Flash & all,
any news with the "solid" trans mount? I thought of replacing my mount soon, so input in this area is highly useful! <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
I know this is an old thread, but I have just recently had SFR build me a solid transmission mount. I have a spare unit if anybody is still looking for one.
Unfortunately, the Lindsey unit doesn't work for the 968; so that is what made me go to SFR.
