No one hurt...just making a gentle left, hit the smallest ice patch(i looked at it afterwards)...fishtailed...recovered...and went 180 the other way off the road into the only street sign for miles....
ps: only the second drive .......
ps: found bondo under the paint just where I hit the door...someone else already been here...
[quote name='xrad' post='48067' date='Feb 23 2008, 09:33 PM']No one hurt...just making a gentle left, hit the smallest ice patch(i looked at it afterwards)...fishtailed...recovered...and went 180 the other way off the road into the only street sign for miles....
ps: found bondo under the paint just where I hit the door...someone else already been here...[/quote]
That sucks! Glad you're ok....doors are easy to find!
LuKe
Ouch! Check ebay for parts.
Yep...Thanks fellas!
found a white 85 944 door for 50$(has the painted upper piece around window). Looks the same except may not have center crease (hidden by plastic moulding strip in pics)
Should be shipped out to me next week. Already got new door handle (150$)and parts from Lindsey racing and used plastic skirts (99$) ebay.
Really low prices, congrats!
Hope you get her back on the road soon.
Driving weather approaches!
apparently...ALL weather is not driving weather..at least for me... <img src="/forum/images/smilies/968/blink.gif" class="smilie" alt="" />
Same thing happened to me last winter. Slow right turn, traded ends, ended sliding up over the curb
backwards and up on the grass. Caused a small crack in the rocker panel that can't be seen and
I spilled some coffee. <img src="/forum/images/smilies/968/ohmy.gif" class="smilie" alt="" /> Lucky was I...
At the time I had factory "open" differential.
Now, car is much more "planted" with new LSD installed,
and a bit more fun to drive. <img src="/forum/images/smilies/968/biggrin.gif" class="smilie" alt="" />
But I was also running the wrong tires for the winter, and I am sure
that played a role in the back end breaking loose. I have since corrected that
problem. I now only run the Bridgestone S0'3's during warmer months.
Sorry about the door, but glad no one was hurt. Good luck with the repair.
-Scott
The hard part might be finding the rocker panel.
Try some of the dismantlers.
I think someone on pelican maybe splitting up a 968?
Have all the parts now except the door.
