Full Version: New tires any recommendations
Hello
I have 17 inch wheels on my club sport which is purely used on road. The UK roads are getting worse by the year hence I need a forgiving tyre, softer side wall etc.
I was thinking about Michelin Pilot 2 but according to Michelin they only come in XL spec, N3!, extra strong side wall for heavier forces, hence I think not the correct tyre for a 968.
It has Bridgestone on at present S02 model, not been really impressed with them.
Any help would be great as tyres change by the year.
MAX PERFORMANCE SUMMER
Category Ratings
<a></a>
<div style="margin:0px;">
<div style="margin:0px 25px 8px 0px;">
<div style="margin:0px 0px 5px;">ORIGINAL EQUIPMENT
<a class="" href="https://www.tirerack.com/tires/tires.jsp?tireMake=Michelin&tireModel=Pilot+Sport+PS2&frontTire=245YR7SPTPS2XLN3&rearTire=54YR7SPORTPS2N3&vehicleSearch=true&fromCompare1=yes&autoMake=Porsche&autoYear=1994&autoModel=968%20Coupe&autoModClar=">[Image: mi_pilot_sport_ps2_sr190.jpg]</a>
<div style="margin:0px;"><span style="margin:0px;color:rgb(46,121,147);">(1,645)</span>
<div style="margin:2px 3px 0px 0px;">
</div>
|<a class="" href="https://www.tirerack.com/tires/tires.jsp?tireMake=Michelin&tireModel=Pilot+Sport+PS2&frontTire=245YR7SPTPS2XLN3&rearTire=54YR7SPORTPS2N3&vehicleSearch=true&fromCompare1=yes&autoMake=Porsche&autoYear=1994&autoModel=968%20Coupe&autoModClar=#RatingsReviews">Reviews (1,234)</a>
</div>
Consumer Recommended
Tire Rack Tested
</div>
<div style="margin:0px;">Click to Compare
</div>
<a class="" href="https://www.tirerack.com/tires/tires.jsp?tireMake=Michelin&tireModel=Pilot+Sport+PS2&frontTire=245YR7SPTPS2XLN3&rearTire=54YR7SPORTPS2N3&vehicleSearch=true&fromCompare1=yes&autoMake=Porsche&autoYear=1994&autoModel=968%20Coupe&autoModClar=">MICHELIN
<span style="margin:0px;font-family:gibsonbold;font-size:26px;">PILOT SPORT PS2</span></a><a class="" href="https://www.tirerack.com/tires/types/modalbox_perfcatdefinition.jsp?perfCat=MP" title="Max Performance Summer">Max Performance Summer</a>
<div style="margin:10px 0px 0px;">
<ul class="">[*]Front: 225/45ZR17 (94Y) XL
[*]N3(Porsche)
[*]Load Range: XL
[*]Serv. Desc: (94Y)
[*]UTQG: 220 AA A
</ul>
<ul class="">[*]
<div style="margin:0px;font-size:13px;">
<div style="margin:0px;">Qty:
Per Tire:
</div>
<div style="margin:0px;font-family:gibsonsemibold;font-size:18px;">
<div style="margin:0px 0px 0px 10px;">2
012345678</div>
<span style="margin:0px;font-family:gibsonregular;font-size:18px;">$179.48</span></div>
[*]Availability: In Stock
Can be deliveredtomorrow, 05/23 to <a class="" href="https://www.tirerack.com/shippingquote/getZip.jsp?newZip=y">18966</a> for $8.27 per tire.
</ul></div>
</div>
<ul class="">[*]Rear: 255/40ZR17 (94Y)
[*]N3(Porsche)
[*]UTQG: 220 AA A
</ul>
<ul class="">[*]
Per Tire:
</div>
012345678</div>
<span style="margin:0px;font-family:gibsonregular;font-size:18px;">$256.60</span></div>
Can be deliveredtomorrow, 05/23 to <a class="" href="https://www.tirerack.com/shippingquote/getZip.jsp?newZip=y">18966</a> for $8.18 per tire.
</ul></div>
</div>
Set of 4: $872.16
Free Road Hazard Protection
($67.94 value. Two-year coverage.)
</div>
Add to Cart
<div>
</div>
</div>
</div>
Check TireRack.com for comparisons.
First off i would forget about N rated, complete waste of time and money on a 25 year old car, the only reason to use N rated is if you have Porsche warranty on the car and even then it not a legal requirement just an advisory
I can assure you that there is no separate production line for N rated tyres they are all the same
I have GT-Radials on my 17 Cup1's they were quite quiet to start with but now after 10K they are starting to get very noisey
if noise and a softer sidewall ride matters then go for an Asymetric tread pattern like Goodyear asymetric
if you are tracking the car the Nankang NS2R but dont use it in the rain!!
I would just go on a tyre site like tyreleader and have a browse at the noise ratings,lower noise softer sidewalls and gentler tread pattern, harder tyres more noise and less rolling resistance
The Michelin Pilot Super Sport has been my favorite road tire on any car I've had it on. Very comfy ride, great grip in dry and wet. I've read that the Pilot Sport 4S takes it even a step further, and is as good of a combination of grip, comfort, and noise as you'll get.
Thanks for info, so would the general opinion be if you go for Michelin tyres is the sport 4 better than pilot sport 2 ?
Will look at Goodyear’s , never had them
What tread pattern is best to resist tram linning?
Roads in Uk are shocking
Any big block tread or big radial grooves will not help, you won't go far wrong with a asymmetric pattern
If you are having big issues with tramlining then have your castor mounts inspected and if they are a bit suspect replace them
Also have your geo checked by someone who knows what they are upto, the rear can really affect the way the front behaves
