Full Version: What wires to splice for 4-Wire trailer harness
Has anyone installed a trailer hitch? If so, what color wires do I splice for a 4 wire trailer harness?
Thanks in advnace!!
On the wire harness:
White: Ground
Brown: Tail Light
Green : RT turn signal / Stop light
Yellow: LT turn signal / Stop light
Thanks in advance!
rlt
ummmm...trailer hitch <img src="/forum/images/smilies/968/blink.gif" class="smilie" alt="" />
is this so you can trailer the 968?
No, pull a small trailer for my track tires and tools.
I will take pix of the hitch at some point over the next week or so.
When I added a hitch I used one of the black boxes that converts the 968's independent stop-tail-turn lights to the standard stop or tail-turn lights found on trailers. It has independent power directly from the battery so the electrical loads on the OE wiring are unchanged. All of the wiring is accessible by removing the rear carpet IIRC.
Towing a tire and tool trailer with the 968 is a piece of cake.
Mike, Where did you get the "black box"? What is it called, who makes one? Did you have to run the wire all the way up to the positive on the battery itself?
Mike,
Figured out that the product is called Modulite and is a powered converter. Can you tell me which wires you hooked up to the converter? Is the Porsche a 2 wire or 3 wire configuration?
all I can say is "nosecone" if you want to get to the track fast!
http://www.nosecone.com/trailer.html
i have one on my race trailer - HUGE improvement in both fuel economy, and more importantly, stability on the road
To hell with the "nosecone," call one of the dismantlers and get yourself a used 968 front bumper to put on the leading edge of the trailer.... That would be true Porsche 968 enthusiam (or lunacy, depending on how you look at it....).
For those who don't know, I believe Porsche offered a factory trailer hitch option for the 968. I am sure it is crazy money, but interesting nonetheless, no?!
lol - it does beg a couple of questions though - not sure i want to know the answers, but just thinking about them gives me a chuckle
I've attached the schematic of the rear lights.
1 BL is Turn Signal
2 BRL is Brake Light
3 BGL is Tail Light
These 2 are not applicable for simple trailers
RFL is Back-up
NSL is Rear Fog Light
There is also a tag light, but most trailers use the tail light bulb for that.
Be sure you verify that everything is working correctly before you button it up! If you do that you won't need any luck.
[attachment=5516]
very cool
Thank you Mike! U-Haul has the powered adapter for 40.00. I am going to install it this afternoon / evening. I will post pix, update as I go through it.
