a little quality time with my 968
so, i finally got a chance to poke in the new spring centered clutch disk in my own car - after having these things out and about for a few months now, and me not having one in my own car, i finally said "enough is enough"
first impressions, after a VERY short drive around the block are:
rattle diminished at least half at idle
rattle essentially gone altogether while driving above second gear
rattle diminished at least half in second, shortened in rev range, and goes away completely with any change in throttle
much smoother engagement of clutch - actually a little weird at first, as it is so smooth
while i was doing the clutch, i also decided to wrap the header with a fiberglass copper inlaid thermal wrap, and then coated it with an aluminum thermal coating - this was to reduce under hood temps, and to reduce the "ricer" sound the header made when it was cold
first impressions (after the initial smoking of the wrap baking in stopped):
much quieter under the hood
definitely cooler under the hood (no measurements yet)
all but eliminated the ricer sound - very happy about this
i also finally got a chance to install the thermal barrier on the underside of my header heat shield (this unit will be available soon)
while it was up in the air, i also took this opportunity to add some strap location points for when i put the car in the trailer - i used the KLA rear cubby plates in the rear, and some single hole units from paragon up front, on one of the bolts for the lower suspension brace - should make for much easier attachment of the tie down straps
i also installed an adjustable voltage regulator - this was to resolve the low idle voltage issue i had as a result of the power pulleys - first impressions - VERY cool - i now have 12.5 at idle, as opposed to 11.8
all in all, a good day
tomorrow i get to drive the car and see how she does - WOOHOO!
Interesting... please report back after your drive.
Joe
Hey Flash, can you be more specific on the front tie downs? Possibly some pictures and can this also be done on a coupe? I look thru Paragon and didn't find any tie downs for the front. Did I miss them or did you adapt something for your vehicle? I would like some front tie downs for my '92 Coupe.
Thanks and I appreciate your help.
Carl
1992, Guards Red, Coupe, 6 spd., LSD, Drilled frt. rotors,
if it works like i think it will ( i have to test everything before i recommend it) - i will definitely post shots
lol - i used a plate they list for something else - as i said though, you have to have the lower suspension brace for it to work
Thanks Flash. That 's what I thought you said, just wanted to be sure.
Carl
no worries - i just want to be sure it doesn't bend under the load before i go suggesting it to other people - if it does bend, i have a solution, it will just involve making a new piece - i thought i would try something that is already out there before doing that though
i have to drag the trailer over here in the new few days anyway - i want to do some work on it - coat the floor, add some lights, add a stereo, add a battery, put the artwork up, add a winch, update the sponsor display, yada yada - while i'm doing all that, i'll stick the car in and make sure this works
second drive results
clutch - smoother shifting - much quieter - pedal engagement is a bit higher - not as positive a shift on fast gear banging, but should do nicely in keeping the disk from fragging, but probably won't get as many tire screeching barks - it will take some getting used to, but feels better overall
header wrap - huge drop in pipe temps - between that and the new heat shield, my intake manifold external temps dropped 20 degrees, and with ambient temp at about 90, was sitting at about 100 - no exhaust noise from under the hood anymore - all from the tailpipe now - cold pipe ricey sound all but gone - very nice - well worth the time and effort
variable voltage regulator - seems to have resolved my problem (now that i fixed the real one) - for details, see: http://www.968forums.com/index.php?showtopic=6062&hl=
[quote name='flash' post='56241' date='Jul 12 2008, 07:26 PM']so, i finally got a chance to poke in the new spring centered clutch disk in my own car - after having these things out and
much smoother engagement of clutch - actually a little weird at first, as it is so smooth[/quote]
What was rattling?
Last Post by Lim Yong
10-18-2008, 01:10 AM
