[quote name='hot968' timestamp='1343087542' post='129859']
Would any one know where to locate the drain hose for the A/C? I looked it up in manual and it shows the part but separate from the car. Can I see it if I look under the dash by the radio?
If I recall correctly, the AC drain hose is behind the radio, and exits the bottom of the car at the top of the "torque tube tunnel" if that's the right word for it, and I had a very clear view of it while I was installing my double-DIN stereo. It's not readily accessible from beneath the car because the torque tube and exhaust are probably in the way.
I'd try looking from the passenger side, then try pulling out the cubby under the radio, but more likely I'd take off the center console and/or remove my radio to get full access. The center console removes very easily with only a few screws, some clips around the shifter boot, and some plugs (be gentle on them) under the switches. Pull the ashtray to get to the first screws, then open the cassette tray door to find a couple more, then remove the screws on each side at the front of the console and proceed from there.
