02-05-2010, 05:27 PM
Hi, I would appreciate some advice on offets for the following rims sizes. I can get them made any offset I want, and have no expereince to judge it. Hence needing some help. So....the story
<b>a: My stock wheel offsets are</b>
f 17"x 7.5" offset 65mm;
r 17" x 9" offset 55mm.
I am looking at 18" race rims, and am limited to the following widths in 18" dia by P.club rules. Since we are changing widths the offset will be a little different than stock
<b>b: The builders suggestion would be</b>
f 18" x 8 33mm offset
r 18" x 9.5" 28mm offset
That still keeps the wheels and tires under the body line in their view, but a more aggressive stance. They can do almost anything I want, and want me to let them know if it is too aggressive or ok. I have no idea.
<b>c: Their standard build for those cars would be this below.</b> But I know this is too wide for my rules so not a build option for me.
18x8.5 offset 47mm
18x10 offset 55mm
<b>The questions</b>
1: What is the exact same offset as stock for the 18" x 8" and 9.5" rims, and is there likely any issue positive or negative just building that?
2: Does anyone have a view on the upside and potential issues of building the rims it as per the 'b: builders suggestion' above?
Appreciate some help from anyone across this sort of wheel detail. Thank you in advance!
P.S just finishing the build of my 968CS club level car...started in Nov and I will post pics and details in about 3 weeks :-)
18x8.5 offset 47mm
18x10 offset 55mm
