My Experience With Hydrocarbon Refrigerants
28 replies to this topic
#21 wiseman
  • Advocate
  • 349 posts
  • City:Tampa
  • State:Florida
  • What year is your 968?:1992
Posted 02 July 2010 - 03:50 AM
Well , I've seen that flap open and shut with the slider but it still comes out of the vents. Maybe this weekend, I'll take it apart and take some pics. Who knows, I could be missing a part or something.
#22 DaveN
    968 Forums Addict
  • Booster
  • PipPipPipPipPipPip
  • 2,593 posts
  • City:Campbell River
  • State:British Columbia
  • What year is your 968?:1993
  • Garage Vehicles:
  • Porsche 968 Coupe (1993)
Posted 02 July 2010 - 08:25 AM
There are 2 motorized actuators under the dash as well opening and closing vents. They are electrically attached to the 2 dash sliders. One is notorious for providing just hot air when the white plastic joiner piece breaks. The other may indeed be the vent problem your having.
#23 wiseman
  • Advocate
  • 349 posts
  • City:Tampa
  • State:Florida
Posted 03 July 2010 - 01:07 PM
Earlier this year when I was under the dash for something else, to the right and up and back a bit, theres a black plastic cover that I remember came off with one screw, behind that cover was a skinny steel arm that was supposed to be atached to one of the motors your talking about. Your right , the white plastic piece was busted, but I wrapped the arm and the other half of the plastic piece with piano wire and it held together so whatever flap or flaps that thing moved, (I couldn't see that far up into the dash) it was operational. I guess I need somebody to tell me how I diagnose this damn thing so I can get in there and get it fixed. I really stink at looking at schematics.
#24 banditsc
    968 Forums Fanatic
  • Admin
  • PipPipPipPipPip
  • 1,784 posts
Posted 03 July 2010 - 02:36 PM
Your fix may not be providing enough tension or it could have popped off. It's suppose to push the flap closed pretty tight.
#25 wiseman
  • Advocate
  • 349 posts
  • City:Tampa
  • State:Florida
Posted 17 August 2010 - 07:08 AM
OK. I recharged the system last weekend with Enviro-Safe. There was pressure in the system and the compressor was cycleing.....just no cold air. Put in a can of Enviro-Safe Stop Leak followed by 2 cans of Enviro-=Safe R12A Refrigerant. The Pressure guage was up to about 50 psi. Temp at the vent is now about 63 degrees on a 96 degree, 75% humidity day. Doesn't seem cold enough to me. Does anybody know what the high and low pressures should be on the guage if all is charged as it should be?
#26 flash
    968 Forums Ex Officio Owner
  • Admin
  • PipPipPipPipPipPipPipPip
  • 28,624 posts
  • City:los angeles
  • State:ca
  • Garage Vehicles:
Posted 17 August 2010 - 07:12 AM
there is a graph - it's in the manual
http://www.cannell.co.uk/Manuals.htm
#27 MoparBoy72
    968 Forums Member
  • PipPipPip
  • 41 posts
  • City:Naperville
  • State:IL
Posted 03 April 2011 - 07:01 PM
This thread has been very helpful; Thank you.
I have a kit on order to set the '92 to R12a and remove those colorful adapers in the engine bay...
#28 968TDubya
    968 Forums Rookie
  • Rookie
  • PipPip
  • 6 posts
  • City:Lubbock
  • State:TX TEXAS
Posted 15 September 2012 - 10:37 PM
I think I will give this a try. Any one else had any luck with it ?
#29 vliegwielolaf1234
  • 501 posts
  • City:Biddinghuizen
  • State:netherlands
Posted 16 September 2012 - 05:02 AM
Changed the pump and dryer 4 years ago and some off the o-rings .
Added oil and 850 gramm of R134a .
Works perfect .
Have to recharge the system next week to change the pressure switch near the dryer
Original R12 car .
Edited by vliegwielolaf1234, 16 September 2012 - 05:04 AM.
