Pinion Bearing
Posted 09 June 2007 - 02:51 PM
There has been a lot of discussion about the pinion bearing noise but no audio samples. Since my 94 968 recently developed the pinion bearing noise, I decided to record some audio samples. I have put the various audio samples below -
• Engine startup
• Start/stop 01
• Start/stop 02
• Start/stop 03
• Coming to a stop
• Highway/75mph
Posted 10 June 2007 - 08:17 AM
Posted 11 June 2007 - 07:50 AM
Cheers,
Posted 11 June 2007 - 08:26 AM
Great Post!
Should link these audio files permanently into to the DIY forum.
Posted 11 June 2007 - 09:16 AM
Posted 11 June 2007 - 10:01 AM
good, very helpful sound clips !
Posted 11 June 2007 - 10:04 AM
Now if we could only get audio recordings of the various exhausts *hint hint*
Posted 11 June 2007 - 10:32 AM
Yay! Thanks for the audio! Now I know that my pinion is still fine
I guess what I hear at high speed is just your regular 'ol gear whine.
Ren,
I haven't forgot about that...just not timed right to have recording gear and cars and people in sync. Cosimo has B&B and Mark has RSBarn, so I think I can get this done soon.
Thanks Flybyu for these clips...now I too know that mine is fine!
Posted 11 June 2007 - 10:52 AM
Posted 11 June 2007 - 02:31 PM
This is a good reference and should be pinned.
Posted 11 June 2007 - 05:39 PM
Stephen G. I am just about to roll over 100,000 miles.
[quote]Should link these audio files permanently into to the DIY forum.[/quote]
RPM. I agree. Does anyone know how to do this?
[quote]lol, my son did not want me to do the repair because he thought having the car sound like it has a jet engine was cool.[/quote]
Dan. That's funny. Just the other day I had an older gentleman in a Mercedes pull up next to me and ask "do you have one of those new hybrid kind of Porschee's? It sounds so unusual." Luckily for me the light changed because I didn't have the heart to tell him that it was a pinion bearing failure.
Thanks everyone! My 968's transmission is currently being repaired by Chris Cervelli. He was previously in AZ with Technodyne Racing and is currently living in CO from what I understand. So, I anxiously await the pocketbook drain and news of any other potential issues. However, I know that it is in good hands between Chris and my mechanic/tuner Exotic Motorwerks. ;-P
Posted 12 June 2007 - 05:31 AM
These recordings are an excellent reference for all of us.
Posted 12 June 2007 - 10:34 AM
Posted 12 June 2007 - 03:17 PM
Posted 13 June 2007 - 07:21 PM
Posted 15 June 2007 - 08:52 PM
'92, 98,000 miles, no bearing noise.
Posted 16 June 2007 - 06:47 AM
factoring in all of the cars over all of the years, the reality is that it's closer to maybe as many as 10% of the cars - that's really high for a failure of a component in a car, but if you think about it, at this age and mileage, it's not any higher than DMF failure
the whole reason this came up as in issue at all is that it was occurring very early on a much higher number of cars than it should have - they determined it to be an installation problem, and therefor a lot of hullaballoo was generated
there is no rhyme or reason - as you will find out later on in this thread as people respond, there are those who have gone a LOT of miles without it failing, those who have had it happen early on, and those who have had it happen it twice
lol - i guess if you could get the car to go enough miles, you might eventually have it, but you are going to have a lot of other far more expensive repairs first (like a complete engine rebuild)
drive the car and don't worry about it - if it happens it happens
Posted 16 June 2007 - 08:46 AM
Posted 10 March 2020 - 12:30 PM
I know this is a very old thread but I am desperate. I am struggling with a droning noise in my 968. The noise starts at around 40mph and disappears (or gets drowned out by windnoise) around 55 to 60mph.
I have tried all kinds of tests to identify the source and have pretty much eliminated all possible sources except for the new rear tires that i recently fitted .
I came across this thread during one of my Google searches for possible causes of my droning noise.
Unfortunately the links to the audio recording files that this thread originator posted, are no longer valid.
If any participants in this thread retained copies to the original audio recordings I will appreciate it very much if you can re-post them or send them to me. They may help me identify or eliminate transmission pinion bearing failure as a source of my droning noise.
Thanks in advance.
Posted 10 March 2020 - 12:50 PM
Your issue does not sound like pinion bearing....the test is to drive to 85 miles an hour and let off the gas, should sound like an airplane engine on decel.
How many miles on your car? More likely is rear wheel bearings.
JMHO,
