Resetting the airbagwarning light
#21
Posted 27 March 2007 - 10:04 PM
ans:I have to correct you the interface has all the four leads.
The only thing what is important is to cut the D4 led out of busniss. Otherwise it is hard to connect to the car or almost impossible.
MIles: Do we need the male 19 pin plug or additional 9 db serial cable as discussed above?
ans: you have to buy the serial cable, because the interface cannot connect in the laptop. It is male versus male. So you have to buy a straight trough 9 pins female female connectercable.
For the first time you can put the leads into the 19 pins connector. Be careful to put them into the right holes.
And Miles As you interface has the D4 led, and is simular to the interface as I described in the first post? The first thing I would do is checking com status, download software and cut of the Led. Cutting of the led, I did it at a place so I could easily repair it. I don't now why but I cut it a centimer above the circuit board.
It is good to see that more people will help me to develop it further.
Ritchie.
#22
Posted 28 March 2007 - 03:44 AM
#23
Posted 28 March 2007 - 04:49 AM
http://www.ecufix.co...products_id=192
#24
Posted 28 March 2007 - 05:17 AM
#25
Posted 28 March 2007 - 05:34 AM
#26
Posted 28 March 2007 - 05:44 AM
I think this is a better link: http://www.ecufix.co...products_id=183
Thanks.. I didn't look at that one since it said ODB-II..
#27
Posted 28 March 2007 - 06:38 AM
#28
Posted 28 March 2007 - 07:19 AM
#29
Posted 28 March 2007 - 07:23 AM
#30
Posted 28 March 2007 - 10:16 AM
I do hope Andy will sell this interface in the future, Because I do not know an other shop who is selling this interface. The complete drawing is in the scantool zip file. Maybe a local electronic shop can order the parts and built it for you.
I'm gladd to see that you guys get more and more enthousiastic!.
I'm still have a big smile when I get in the car and think this car won't trick me anymore with an airbaglight! Because I have it under control and don't have to see the OPC.
I just checked Andy's website: there is one left.....
#31
Posted 29 March 2007 - 12:51 PM
I think we cleaned them out!
Regards,
Miles
ps i went to Radio Shck and bought the rest of the parts needed to complete this project, so all I need now is for the board from Andy's to be delivered!!!!
#32
Posted 30 March 2007 - 01:24 AM
#33
Posted 07 May 2007 - 08:25 AM
#34
Posted 07 May 2007 - 09:57 AM
#35
Posted 07 May 2007 - 03:44 PM
If you bought the Porsche specific plug you will need to make sure your pins are pushed all the way in so that they stick out far enough to make contact. I filed down the front of plug just a little so that the pins stick out just a little more as I had difficulty making contact with the cars plug. Now I'm sure I make contact with the car as I have tested and retested to make sure I am getting the signal.
This was were I had my first problem, so I hope you won't have the same problem. If you are crawling under the dash and plugging the wires directly in to the car's plug this obviously won't be an issue.
Keep us posted and have a safe trip
Regards
Miles
ps I did cut the D4 LED and still no luck, but I'm convinced it is the serial adapter that I have been using. The next test I will perform is to drag the desktop with built in serial port to the garage. If the COM port is not assigned to COM Port 1 the software will not stay on after it has been launched.
#36
Posted 07 May 2007 - 04:03 PM
#37
Posted 08 May 2007 - 09:37 AM
I have done a search for the components on the interface here in Europe. I can get al the components for assembly the interface. I can arrange this for those who are interestted in it. So let me know if you are interested with a private email that I can put you on the list.
Darryl, your friends son can better buy an interface with the software from Rosstech.
http://www.ross-tech.com/vag-com
Special made for VW and Audi. It is a great program for a couple of bucks!.
#38
Posted 10 May 2007 - 01:45 AM
http://www.968forums...?showtopic=3881
Other faultcodes from the airbagsystem are:
Ign. circuits
Frt.sensor left
Frt.sensor.right
Ign.pill.circ.1 (driver side)
Ign.pill.circ.2 (passenger side)
Ign.pill.circ.3 (passenger side)
Airbag warning light.
I've already updated the FAQ.
#39
Posted 11 May 2007 - 04:13 PM
fingers crossed
Miles
#40
Posted 12 May 2007 - 12:33 AM
