Help needed: post PPI concerns
PPI concerns: post #1'>
PPI concerns: post #1' />
Posted 22 August 2014 - 01:06 PM
I've done my best at due diligence, checked car history, done a personal inspection, and taken the car for a PPI. However, I'm new to the PPI mechanic as well as Porsches, so if you could answer my few remaining doubts, I'd be much obliged. Car: '92 coupe with 60k miles.
1) A compression test indicated 14:14:14:12 on the four cylinders. The mechanic says the variation is within acceptable tolerance. Is this true? Is it indicative of work I'll need later?
2) If I hold my hand on it while driving, the stick shift tugs every so often, like a flick towards center then back to where it was before. The mechanic says this is probably a loose mount somewhere, but nothing to worry about.
3) Oil pressure when engine is hot and the car is in gear stays around 4. In neutral and idling it's between 2 and 3. Is this normal?
4) Mechanic says the rear brakes are rusty, most likely from not being driven much, and hopefully driving will wear off the rust, otherwise I'll need new pads. True?
5) Currently spark plugs are Beru and mechanic says if I buy the car I should replace with Bosch. Not sure if he's trying to generate business for himself but a quick Google search seems to agree. Not as concerned about this as the other things.
Apparently the front and rear body panels have been painted, due to rock chips or something else. No records I can find of an accident, but this is Europe and the car has been through a couple countries before landing here. Other than that little nicks here and there, a couple holes in the plastic grill near the bottom (probably rock), and the front wheel mudflap? is a little torn up on the inside, driving over more rocks I guess.
Thanks for help answering my question guys so I can put my fears to rest and make an offer.
Cheers,
D.
PPI concerns: post #2'>
PPI concerns: post #2' />
Posted 22 August 2014 - 01:31 PM
the stick shift should move, as you are on and off throttle. it should stay put at steady state.
oil is normal.
brakes - rust should scuff off from driving. it it doesn't, then pads and rotors will be indicated.
bosch copper plugs are fine for daily driver stuff. ngk iridiums will last longer and run better. bosch platinums will last the longest, but not perform as well.
PPI concerns: post #3'>
PPI concerns: post #3' />
Posted 22 August 2014 - 09:21 PM
PPI concerns: post #4'>
PPI concerns: post #4' />
Posted 22 August 2014 - 10:17 PM
PPI concerns: post #5'>
PPI concerns: post #5' />
Posted 23 August 2014 - 05:51 AM
the other thing that could be going on is that you have a lot of carbon in the other cylinders. the numbers are actually a bit high on those. so, if you cleaned out the carbon, the numbers might even out.
PPI concerns: post #6'>
PPI concerns: post #6' />
Posted 23 August 2014 - 07:35 PM
holes in the lower grill, which is plastic and probably fairly brittle, are also normal. I had numerous holes before I replaced the lower grill with one from Design One Racing. I did this after about 90k miles. These are unfortunately no longer available (NLA).
rotors, pads, and plugs are all relatively inexpensive. Changing spark plugs on the 968 is easier than any car I have ever
had.
most of the time you are looking for stuff like oil leaks, seepage around the balance shaft housings and also around where the head mates to the block.
You'll want to know a few more things: (forgive me if you have already covered these items).
1. Any pinion bearing service, problems, or even better, has it been replaced?
2. When was last timing belt/water pump replacement? Should be 3 years / 45k miles, whichever comes first.
3. Vario-cam pads and chain - original or replaced? You'll want to get those pads done if they are original.
#2, above, is an $1,800 job at a shop. Many here would recommend not driving the car if the timing belt is past the replacement interval of 3yrs/45k miles.
Best of luck with the car. I hope it passes muster in all of these areas.
Cheers!
-Scott
PPI concerns: post #7'>
PPI concerns: post #7' />
Posted 24 August 2014 - 04:08 AM
PPI concerns: post #8'>
PPI concerns: post #8' />
Posted 24 August 2014 - 07:21 AM
Edited by PorscheG96, 24 August 2014 - 07:22 AM.
PPI concerns: post #9'>
PPI concerns: post #9' />
Posted 25 August 2014 - 02:32 AM
I talked to the mechanic that did my PPI today and he said that indeed the fourth cylinder's compression was off by 2 kbars, but the engine ran fine when he drove it so he doesn't think it was worth worrying about now or preventing me from making the purchase. I don't know how paranoid I should be and insist on a redo and a leakdown test. :\
PPI concerns: post #10'>
PPI concerns: post #10' />
Posted 25 August 2014 - 02:56 AM
PPI concerns: post #11'>
PPI concerns: post #11' />
Posted 25 August 2014 - 10:38 AM
The vario-cam pads become brittle and pitted over time and can fail. Porsche does not specify a replacement interval, but my recommendation is to replace them along with the
chain. No need to inspect them and it's a relatively easy job for a trained mechanic. I think I paid $250 plus parts, which were about $50.
Here's a DIY on the vario-cam inspection:
Edited by Scott Collins, 25 August 2014 - 10:38 AM.
PPI concerns: post #12'>
PPI concerns: post #12' />
Posted 03 November 2016 - 02:24 PM
PPI concerns: post #13'>
PPI concerns: post #13' />
Posted 03 November 2016 - 05:40 PM
Reach out to BanditSC here...he lives in Charleston and is very tied in to the Porsche community...
Regards,
PPI concerns: post #14'>
PPI concerns: post #14' />
Posted 04 November 2016 - 01:40 AM
