968 Automatic / Tiptronic Transmissions
Posted 19 February 2013 - 06:40 AM
I prefer a standard tranny, but thought I would ask?
There is quite a difference in car prices between manual & tiptronic.
Mylz87
Posted 19 February 2013 - 07:07 AM
I had both. I liked them both. The tip is slower but if you do a lot of stop and go driving it was nice to not shift gears. I had mine 6 years and drove it 35,000 km with no problems at all. It was more fun to drive in the tip mode than in the auto mode. I probably didn't drive it more than 10 km overall in the auto mode.
I sold the tip only because I now have a 911 Cab and didn't want or need two convertibles.
Posted 19 February 2013 - 07:15 AM
if the tip trans needs work, it will be more expensive than the manual trans
it really depends on what you want to do with the car
Posted 19 February 2013 - 07:38 AM
Posted 19 February 2013 - 07:56 AM
JMO,
Posted 19 February 2013 - 08:01 AM
I agree the manual is more fun to drive, especialy on a weekend driver.
Mylz87
Posted 19 February 2013 - 08:20 AM
Posted 19 February 2013 - 08:58 AM
Posted 19 February 2013 - 09:06 AM
driving the tip can take some learning if you want all of the performance from it, but can be driven very fast. we have a couple of members who race them and do very well.
if and when it fails, the flex dampener is indeed expensive, but no more so really than the dual mass flywheel in the manual cars, which in many cars also need replacing. there are a few more hours of labor involved, but it isn't the end of the world, and once it's done, you won't have to do it again.
as for resale price, a tip will generally go for $2k to $3k less than an otherwise identical car. similarly typically white and red cars go for less than other colors. the market has made choices as to what it finds valuable. of course, with this small of a block of cars, there will be exceptions to those "rules". after watching for 9 years though, this is what i have seen.
Posted 19 February 2013 - 12:52 PM
I never thought about colors effecting car value, but it makes sense. Also, the pinion gear worry disapears with a tip, thanks.
Whats the best a way to determine tiptronic tranny condition?
The more I keep researching, the more ways there are to spend $$ on these toys
mylz87.
Posted 19 February 2013 - 12:53 PM
The only reliability issue I've noticed with the Tip is that the transmission mount might break and the plastic ATF fluid reservoir will certainly break if your teenage son looses control, spins it into a ditch, and totals the car.
Posted 19 February 2013 - 07:41 PM
Posted 19 February 2013 - 09:06 PM
Posted 20 February 2013 - 04:38 AM
Like Flash said, you have to learn how to drive it to get the most out of it and yes, will probably need a flex plate due to age (mine did) but a great car.
Posted 20 February 2013 - 09:22 AM
Posted 21 February 2013 - 08:24 AM
