Anybody deal with Higher Connections lately?
Posted 18 May 2012 - 03:20 PM
Posted 18 May 2012 - 07:49 PM
Posted 19 May 2012 - 04:48 AM
Posted 19 May 2012 - 05:15 AM
Posted 19 May 2012 - 06:21 AM
still, in a race car, getting that weight off the front, and into the rear, makes a pretty big difference when it comes time to corner balancing
Posted 20 May 2012 - 12:41 PM
can it be done for $300??
Posted 20 May 2012 - 03:21 PM
Posted 20 May 2012 - 04:10 PM
Posted 21 May 2012 - 06:00 AM
Posted 21 May 2012 - 06:06 AM
i agree that is is a lot of work. it also isn't cheap. but, it did help with the corner balancing. i was able to get within a couple of pounds at each corner.
yes, it can be done for under $300, but not by much, after factoring in the cable, connectors, terminal block, and tray kit.
the upside is that i picked up a half volt at the battery.
back to the original question, i know robbie was trying to get going again, and was going through a tough time. i have not spoken to him in a while, but am sending him a letter shortly.
Posted 21 May 2012 - 07:11 AM
Posted 27 May 2012 - 12:00 PM
I removed the spare and exhaust from the rear and wanted to remove weight from the front.
thats the plan.....no luck so far
Posted 27 May 2012 - 12:17 PM
Now that I'm FINALLY done with my daughter's car stereo install, I plan to tackle a fixed headlight conversion for my car. I'll let everybody know how it goes.
Posted 27 May 2012 - 02:43 PM
when i had the light flywheel and power pulleys, i was frequently in deficit mode. a small battery might have caused me problems. that is exactly what led me to move mine rather than go small. it's a street car, and i have a stereo, and like to run AC, therefore i needed a bigger battery so it didn't dip.
Posted 27 May 2012 - 05:09 PM
It's a tough call, and it depends on how the car is driven. But I would venture that most people wouldn't notice the benefits of moving the battery to the back in a street application, as appealing of a mod as it sounds. But, for some people, this car is a project, and balancing out the car by moving the battery to the back is definitely cool.
Posted 10 June 2012 - 01:14 PM
replace the battery.
Anyway, love to get a battery relocation kit and a nice clean fix headlight solution.
Posted 10 June 2012 - 01:24 PM
Have you seen Pablo Crespo's car? It's a race car, but the fixed headlight conversion he has on it is about the nicest I've seen which retains the stock fender. What sets his apart is that his lexan covers are slightly curved to follow the curve of the fender; the other similar conversions I've seen all use flat lexan covers. AJ Hartman Racing did Pablo's conversion - you might want to check out their web site.
Posted 10 June 2012 - 01:43 PM
Posted 10 June 2012 - 03:18 PM
Posted 17 June 2012 - 12:15 PM
thanks for that info..I'll check on it.
