968 Golden Rules
Posted 09 September 2005 - 06:17 PM
Please make these recommendations based on accepted Porsche service intervals or accepted common knowledge and personal experience.
OK, I'll start:
DO - change your timing and balance belts every 48,000 miles or 5? years, (my guess as my documents don't show a time interval). Doing the rollers every other change would be a prudent move too.
DON'T - Press the trip reset button while the vehicle is in motion. For some reason this can cause the gears in the odometer to strip and disable your odometer.
Posted 09 September 2005 - 06:43 PM
DO NOT - leave a perfectly flat surface after installing a front airdam splitter!
Posted 09 September 2005 - 07:12 PM
Posted 09 September 2005 - 08:09 PM
One, rather long, line. Someone was watching "Conjunction Junction"DO NOT move vehicle with parking brake engaged - the resultant grinding sound from the brake shoes that locked up inside the rotor because the retainer pin snapped will ruin your favorite song on the radio, cause you to discover new muscles in your nether regions, loosen the fillings in your teeth, and send you searching for your AAA card
Keep 'em coming
DO - feed the fuel tank the highest octane gas you can find. The 11:1 compression ratio dragon is HUNGRY.
DO - Change the DME relay when you buy the car and keep a spare in the glove box.
Posted 09 September 2005 - 08:22 PM
DO: Change your heater control valve when you buy a 968 (For peice of mind)
DO NOT: Leave home without a Spare Heater Control Valve & DME
Posted 09 September 2005 - 08:25 PM
DO NOT: Buy a car without having a Pre Purchase inspection done first.
Posted 10 September 2005 - 05:55 AM
DO NOT try to raise the top with the boot cover on - BOINK - $1000
DO stop immediately if there are odd noises happening during operation - BOINK - $1000
Posted 10 September 2005 - 08:34 AM
Posted 16 September 2005 - 02:01 PM
Renron
Posted 16 September 2005 - 06:18 PM
DO: Close the hatch by pulling on the little winglet under the main wing. It helps relieve the stress on the fragile bolt attachemts and keeps the fingerprints off the visible part of the spoiler (credit: Mr. Midblue on this one)
More, more, more!
Posted 17 September 2005 - 08:20 AM
Do upgrade to a LSD if you don't already have. A fellow over at R.L..com made a quote I have never been able to forget, "A Porsche without LSD is like a woman without a vagina". A little crude and extreme but gets the point across.
DO NOT leave your car parked for over a week or two (especially in very hot or cold weather) without a trickle charger and expect to return to a battery with enough charge to start your big ole' 3.0L engine. The parasitic current on these cars can be nasty, especially with alarm systems and aftermarket stereos or navigation systems... well you get the point.
Posted 17 September 2005 - 09:51 AM
Mwah, I frequently leave mine at the airport for up to 6 weeks, even in winter it is no problem with a good battery
Posted 17 September 2005 - 02:30 PM
Bleh, well that's good to know. I had read about other 968 owners complaining of batteries draining quickly, so I just assumed when mine did also this was something normal for the model. The OP had a highend stereo shop put in a fairly over the top Alpine system in my 968. I will get out the old trusty multimeter and see exactly what is going on with my car and start a new thread about it soonish.
I only drive my 968 for fun to keep the miles low and as I am trying to get as many miles on the BMW as possible (its at 145k now and would like to get it up close to 300k some day). Anyway it would be nice to not have to worry about keeping the battery on the 968 charged if I don't get a chance to take it for a spin weekly.
Anyway, I guess I should add a new DO/DO NOT so I don't get accussed of highjacking this thread
DO NOT assume a problem you and a few others are having with these cars (whether it is poor low end torque, quick battery drains, or funny clutch vibrations) is just status quo for the model.
DO share any problems with your 968 to the online community to get others opinions and advise.
Posted 17 September 2005 - 06:58 PM
I just had a clutch pack replacement and when they checked the clutch hydraulic fluid they discovered that when I had the car serviced they did not do the clutch fluids, only the brakes.
DO NOT assume that when you ask to have the hydraulic fluid replaced that they will also do the clutch hydraulics.
Posted 22 September 2005 - 12:17 PM
DONT: If not all of the 'anti squeaking plates' are available, do not use (even partial) the old ones.
Joerg
(with 2 used anti sqeak plates in the left rear)
Posted 06 October 2005 - 08:10 AM
Cheap insurance!!!!
Renron
Posted 24 October 2005 - 05:11 PM
Thanks!!!
Do protect those expensive Headlights and Driving lights with "Stoneguard" film
Cheap insurance!!!!
Renron
Posted 25 October 2005 - 05:20 AM
DON'T: fill your cooling system with the 'green' stuff - we're only supposed to use phosphate free coolant which is ORANGE in color.
Posted 25 October 2005 - 03:41 PM
