Looking for some DIY .pdf files
Posted 03 April 2012 - 08:38 AM
Appreciate any help.
Posted 03 April 2012 - 08:56 AM
Posted 03 April 2012 - 11:23 AM
Posted 03 April 2012 - 11:57 AM
Posted 03 April 2012 - 04:59 PM
Posted 03 April 2012 - 05:57 PM
Posted 03 April 2012 - 06:36 PM
Cloud9...68, sent you an IM.
Thanks for the quick response,
Greg
Posted 03 April 2012 - 07:51 PM
Email is on the way. Let me know if you have trouble seeing the attachment. It's a pdf, not a Word document, as it turns out.
Posted 04 April 2012 - 04:24 AM
Posted 04 April 2012 - 04:37 AM
Posted 04 April 2012 - 05:34 AM
Posted 04 April 2012 - 08:45 AM
I'm having trouble seeing where the modified "cutting" procedure departs from the .pdf procedure.
In the old thread, it said "The difference between doing the replacement with the cut, and proper replacement, is: the "cut" only requires removing one bolt, the one holding the door handle in place. The "proper" replacement requires doing that, plus removing the door handle electrical connector and the two mechanical links so the the handle can be completely separated from the car.
If you are not disconnecting anything from the door handle (and cutting the gasket so you can pass it around wires/rods) do you still have to take the door panel off?
I'm not trying to be dense, I just like to know exactly what I'm getting myself into before I start. I fear putting my car out of commission because I disassembled the door and can't get it back together.
If it's possible to just unscrew the 5mm screw, pull the handle away from the door, put the gasket around the rods, and put the handle back, I'd just as soon skip all the door panel disassembly. Maybe that's just wishful thinking.
Posted 04 April 2012 - 10:27 AM
I also cleaned the mechanism thoroughly with Brake Clean and put a small amount of good spray lube (not WD40) on the moving parts.
Posted 04 April 2012 - 11:17 AM
Posted 04 April 2012 - 12:20 PM
Posted 04 April 2012 - 04:52 PM
Would someone send me the side cladding gasket replacement pdf file also? I'm very hesitant to do this without some instruction and best practices; expecting to break some fasteners...
Posted 04 April 2012 - 05:59 PM
Posted 04 April 2012 - 06:53 PM
Posted 04 April 2012 - 09:51 PM
Posted 09 April 2012 - 10:11 AM
