Considering a purchase, but some questions remain
Posted 07 March 2012 - 03:48 AM
I am considering the purchase of a 968 with a little more than 100k miles on it. The car seems well maintained (and has complete service records), and you can tell that the seller is into cars and knows what he is doing.
However, the car has only been driven 4,000 miles since 2008 which is also when the last big service was done. Since then, just the yearly oil changes and one brake fluid change. The timing belt was replaced in 2004 and adjusted in 2005 about 15,000 miles ago. Now I am not sure what that means for me when I buy the car. Is there a back log of maintnance now, and does e.g. the timing have to be replaced right away? Or will it be OK since the millage accumulated since than has been relatively small?
Also, should I try to gat a PPI even though there are complete records available?
Thanks a lot for your advice,
HK968
Posted 07 March 2012 - 04:21 AM
Posted 07 March 2012 - 06:09 AM
Edited by 94SilverCab, 07 March 2012 - 06:09 AM.
Posted 07 March 2012 - 06:35 AM
Posted 07 March 2012 - 06:45 AM
Posted 07 March 2012 - 08:59 AM
What year 968?
Definitely replace timing and balance belts. The belts are about $150 and the labor is another $1,100, unless you DIY.
The other potentially big item is transmission, and if operating properly, it should be fairly quiet when driving. If you hear whining, that's a potential problem. The issue in our transmissions is the pinion bearing, that has been know to fail. Check the service history to see if the previous owner(S) have had that replaced. If so, then you are good.
Great cars and so much fun driving that it's well worth the time and money.
Cheers!
-Scott
Posted 07 March 2012 - 10:53 AM
One thing I've thought about for a long time is taking a basic auto maintenance class at the local community college. Even though I've worked on cars as a hobby my whole life, I figure this would be a great way to learn a bunch of stuff I wasn't previously aware of. So, my recommendation would be to get a thorough PPI, then do a search on this site of the items the PPI uncovers, and, starting with the best trade-off of the simplest/most urgent items, dive on in! But, of course, this assumes the 968 isn't needed as your daily driver, that you have a garage, tools, etc. Otherwise, as others have said, budged many thousands of dollars in repairs on top of the purchase price.
OK, off my soap box. Best of luck either way; these are really special cars.
Edited by Cloud9...68, 07 March 2012 - 10:54 AM.
Posted 07 March 2012 - 04:26 PM
Posted 07 March 2012 - 04:28 PM
Posted 07 March 2012 - 04:57 PM
I used to do a (very) little bit on my Miata, because I could afford to break it. The 968 I polish, gas and check fluids and air.
JMHO,
Posted 07 March 2012 - 04:59 PM
Posted 07 March 2012 - 05:46 PM
Also, it seems to be the concensus that I should do a PPI - and right you are! I just thought about it, and the first thing that I would do after I buy the car is to take it to a shop to have it checked out - so it makes every sense to do this BEFORE I actually pay
HK968
Posted 07 March 2012 - 06:12 PM
Posted 07 March 2012 - 07:02 PM
Now lets see how things work out - I'll keep you posted ....
Posted 07 March 2012 - 08:25 PM
Gasp! I see why they call it a "clutch" job - that's what I would be doing to my chest when presented with an estimate like that!Quote on my clutch right now is $3K.
Posted 07 March 2012 - 09:57 PM
HK, welcome and good luck on your purchase. The advice you have received here is spot on. Mine had only 4,500 k on the belts but they had been done about 6 years back. I wasted no time having them changed.
Posted 08 March 2012 - 03:30 AM
With that being said, I purchased all the parts myself and am just waiting for spring to put it on a friend's lift and do the job myself. I considered doing it on jack stands, but I'm not interested in that much frustration. I am also strongly considering just purchasing a lift myself for that amount of money.
Posted 08 March 2012 - 03:55 AM
Posted 08 March 2012 - 05:21 AM
Ah, yes, a lift. Definitely on my list of things I'd love to own. I took my clutch and flywheel out with the car on jackstands - oh what fun to turn the engine an eighth of a revolution at the front pulley, get under the car, install the flywheel lock, slightly loosen a bolt, remove the lock, go to the front of the car to turn the engine another eighth of a revolution, and repeat, over and over and over, because you want to loosen the bolts gradually. A lift would have made it much more comfortable. But I'm so cheap that I would rather do this with broken glass all over the garage floor than pay someone $1500 in labor.
Which pressure plate did you get? Apparently, there is a very limited supply of actual 968 pressure plates. There's one for the 964 that technically works, but, and I'm probably not going to get this exactly right, the clutch pedal pivot points are different for the two cars, so using a 964 plate in a 968 results in an excessively heavy pedal, with not additional force actually being applied to the disk. At least that's what Pete from RS Barn told me.
Posted 08 March 2012 - 08:37 AM
pressure plate: that's essentially correct.
