Pinion Bearing Problem
Posted 23 August 2005 - 05:33 PM
(Note: Much of this compiled from random sources, but heavily from
http://members.rennlist.org/martin)
What is a pinion bearing: the 968 has a transaxsle i.e. the gearbox, final drive and differential all in one unit. The gearbox output shaft has at its end a pinion gear driving the crown wheel. This shaft has a big 'pinion' bearing on one end and a smaller one at the other end. A pre-load is applied by way of shims and a nut at the smaller end of the shaft.
Who gets this problem? It is a manufacturing defect in some cars. Some people are guessing from 2% to 10% of our cars. It seems to happen anywhere from 0 to 80K miles, with very few instances over 90K miles.
How do you know you have the problem? The main indicator seems to be a noise similar to the whine of a jet engine. Common tests for the problem include running the car up to about 80mph on a smooth road to avoid road noise, coast, and listening for the jet engine noise coming from the rear of the car.
How much does it cost to fix? Anywhere from $1500 to $3000 it seems depending on where you get it done. It is a complicated procedure to fix so make sure the shop has good knowledge of the 968.
Posted 31 May 2009 - 02:18 PM
bugger! Any further tips or advice? Perana 302
Posted 31 May 2009 - 03:43 PM
Posted 31 May 2009 - 04:04 PM
Posted 31 May 2009 - 07:02 PM
The bearing is in the transmission....
Regards,
Posted 31 May 2009 - 07:24 PM
Edited by stewhatch, 31 May 2009 - 07:27 PM.
Posted 01 June 2009 - 01:51 PM
Posted 01 June 2009 - 02:01 PM
Posted 01 June 2009 - 03:25 PM
the percentage of failures did not even come close to meeting the number for a mandatory recall campain .. so would
porsche just do the right thing for their customers, voluntarily .. ?? nooooooo
basta*ds ! unfortunatelly for me too, because my car was also "blessed" with that great jet engine sound
Edited by ds968, 01 June 2009 - 06:02 PM.
Posted 01 June 2009 - 05:42 PM
I was pretty sure it was in it but not positive
Thanks again
Posted 02 June 2009 - 01:52 AM
Remember Slapshot?
IIRC wasn't there a N.American based group that approached Porsche about addressing this problem when this issue gained prominence?
Posted 02 June 2009 - 01:03 PM
