Threads: 13
Jason,
I have had good luck with Kumho Victoracers. I have heard that they aren't as sticky as Hoosiers or MPSCs (after they warm up). I don't have any experience with the others because the Kumhos are usually almost half the price of the others and since they work well for me I haven't tried the others. They also come up to temp fairly quickly. All that being said, they don't make them for anything larger than a 17" rim and IIRC, you are running 18s. They do make the ECSTA V700 and V710 R-compounds in 18s, but I don't know anything about them either except that they are closer to the Hoosier and MPSC in price.
Good Luck,
mike
93 911 C2 Coupe
Threads: 5
What sizes are you running?
Jim Child
'94 968 PCA E-Stock/NASA GTS2
'01 Boxster
Threads: 5
I run Hoosiers in 245/35/18 on 8.5" fronts and 285/30/18 on 10" rears. With my setup I don't typically have understeer problems, and I know several other 968/951racers who are also running this combination successfully. According to the Hoosier website you can run the 245/35/18 tires on a 8.0" to 9.5" rim, and the 285/30/18 tires on a 10" to 11" rim. IMO the R6 is the best DOT tire Hoosier has ever made. Lots of grip, and better wear than any previous Hoosier DOT model. I ran them all season in 2006, and didn't cord a single tire. I found that they would slow down a bit after a couple of weekends due to heat cycles, but that shouldn't be a problem if you're just doing DE's. That said, they still won't last as long as Toyos, so Eric's suggestion might be a better one if you can fit a 275 up front.
Jim Child
'01 Boxster
