Here are the Part Numbers....For NON Cab 968's
Lower Spoiler........................................................944 512 103 01 03c
Stoplamp assembly ( 3 part ) .................................951 631 060 00
Lamp Insert Bracket ..............................................951 631 121 00
Lens Screws x 2 ....................................................N014 123 4 ( each )
and if req. New Lower Spoiler Rubber gasket..........951 512 603 00
Replacement Bulbs...............................999 631 030 90 ( each )
Fitting is fairly easy although new wiring has to be "chased" from the Lamp Insert bracket connections
to inside the rear hatch in order to connect up to the stop& tail lamp wiring. The factory uses flat elec.wiring for this but for the after-market fitting I ran the two wires along inside the lower spoiler and across/inside the left hand side side channel and through the hatch by filing two grooves in the soft underside of the hatch
to accomodate the two wires without crushing them too much.
I was greatly helped by Dave Griemann who e-mailed me some pics of his car's assembly and wiring.
Although he has suspended operations temporarily ; you can still access a D-I-Y upgrade for the bulb assembly on the
WWW.968engineering.com website.
Cheers Shaun
