08-22-2009, 06:27 PM
for 5 years now i have felt that my car seemed to be doing a one step forward, two steps back thing - while i would gain upper end horsepower, i would seemingly lose low end torque
also, i would periodically get a variocam intermittent fault code when i did a blink test - no other faults - no check engine light - no big red light - i presumed a loose connection, fiddled with it and the hall sensor, which i knew to have a crumbly connector, and things "seemed" ok afterward
about 2 weeks ago, i was driving the car, and it really seemed limp, especially between 2k and 4k - this had happened before, but i chalked it up to cars running differently on different days - however, this was more so than i had remembered before - still though, no check engine light - no big red light (didn't do a blink test) - i was pretty disgusted and really feeling like maybe i was about done with this car
then, while out the other day with t-bone, the car suddenly developed a new symptom - at about 5k it felt like somebody had smacked the car - BAM! - it was far worse than the fuel cutout of over-rev - i let it back down, brought it back up - BAM! - it also idled a little high and chugged pretty bad off the line - ok - back to the garage
this time i plugged in the laptop and pulled the codes with the durametric - HALL SENDER and MAF - what the heck?
i had just cleaned the MAF and air filter, so i figured maybe i got something on it - cleaned the MAF again
the hall sender was disconnected, so i reconnected it - i figured that was it
reset the codes - run it again - HALL SENDER - crap
inspected the connector and wire - wire was crimped under the valve cover - must have done it when i did the belts - ok - damaged wire - cut out the bad wire and put in new wire - change connector while we're at it - put it back together - fire it up - HALL SENDER - crap!
take it all apart again - this time let's remove the sender and get better access - BINGO! shattered hall sender - ok - order a new one
today i finally got her buttoned back up, and took it for a quick spin - WOOHOO!! - this thing is a rocket! before when i would step on it at 2.5k in 4th it would just sit there - now it actually pulls - it pushed me back in the seat and everything - it's not like rubber burning V8 power, but it is really very nice - it pulls straight up and through, much smoother now as it crosses over the boost point of 4.3 and goes straight to redline - i had to back out of it in a hurry - very much more fun now
ok - maybe i'll keep it
bugs me that the car can have something like this wrong with it, and you never know about it - it took the durametric to figure it out - best thing i've done in a while
