Threads: 5
Harnesses attached to the rear seat belt mounting points without a harness guide bar are not safe. Don't go that route. Your best bet is to get a good bar and put it in for DE's and take it back out for street use. Installation and de-installation should only take you about 15 minutes. The best harness bar is actually a combination harness bar and roll bar that bolts into the rear seat belt mounting points. Its the Redline RollBar:
http://www.homestead.com/redlinerennspor...dPage.html
Keep in mind that if you use 5 point harneses you really need to be using a racing seat with holes for the harnesses to pass through. Harnesses with the stock seat can slip off of your shoulders and are therefore considered less safe than the stock three point belts. Many DE organizations are now insisting that you use racing seats with harnesses.
Jim Child
'94 968 PCA E-Stock/NASA GTS2
'01 Boxster
Threads: 5
[quote name='Cloud9...68' post='38571' date='Jul 21 2007, 03:13 PM']I've heard many people say that a good seat/harness will increase your speed significantly, because you can focus even more on the task at hand, without having to worry about sliding around in your seat, but I'm finding that a little hard to comprehend at this point in my driving "career." Did you experience a big improvement when you went with a racing seat/harness? Or do you really have to get a lot faster before things like this start to make a difference? Thanks.[/quote]
Do you find yourself using the steering wheel to brace yourself in position in addition to using it to steer the car? Do you use your left foot to brace yourself in position, and then lose this bracing when you go for the clutch or left foot braking? Harnesses and a proper racing seat will fix these problems. I did see a performance increase when I installed them, and if you're experiencing the problems I mentioned then I suspect you will too. Just make sure end up with a safe installation.
Jim Child
'01 Boxster
Threads: 14
Another consideration along the same lines is rollover protection. If you get good seats and 5-6 pt harnesses, please ensure you get some sort of rollover protection.
The harnesses will keep you in your seat very well. This means they will keep you seated upright in the event of a rollover. Needless to say this could easily have disasterous ramifications.
I really didn't like my Sparco Rev too much. They flexed too much and rolled my shoulders forward awkwardly. I guess my point is to sit in whatever seat you're going to use...I had Sparco Evos and a Momo Acropolis at one point and they were fine. My next seat will be built to work with a Hans or Isaac device.
Joel Wahlsten
Threads: 14
IMHO you'd be better served by making the driver more comfortable, and the cockpit safer. I bet you'll get better lap times out of that than redoing the suspension. I know they lean a good bit, but they still hold the road very well...
I'm looking at getting the Redline bar as well. I just can't see going back out on the track without some type of rollbar. I have a Brey-Krause Harness truss, but I won't use it except for auto-x.
Joel Wahlsten
(This post was last modified: 07-23-2007, 04:26 PM by
JWahlsten.)
Threads: 14
Makes sense to me, but his level of experience and yours are slightly different. Once his butt-o-meter is better calibrated he should be able to say what kind of mods he wants to do to the suspension.
I know I drove my first 951 quickly on just the factory M030 suspension for my first 10 events. It allowed me to learn the car and gave me a stable configuration on which to learn...
I need to get this car out to the track with the 968 M030 configuration to see what all the fuss is about. It sure autocrosses great even though it rolls a bit.
Joel Wahlsten
Threads: 14
Let's just say BTDT. I was going through turn 3 at Summit Point, and the boost hit hard and the tires weren't buying it...The car spun once, I put both feet in, tried to steer it, but ended sliding through the gravel trap until the car almost came to a stop. Of course, it didn't or we wouldn't be here now would we? It caught something on the passenger side rear flipped up on its side, and sat there for a second until it went on the roof.
Now, this has something to do with why I recommend some sort of rollover protection when you start going fast, but it isn't the only reason. I am an evaluator pilot with about 4100 hours in heavy jet aircraft. Safety is a BIG deal in the flying community, and most of us are type-A personalities. That being said I've done a good bit of research on belts, seats, and safety equipment.
Think of it this way, and I think I already went here, but I will again. Picture yourself rigidly pinned upright in your seat (a good harness will do this for you). Your rear tire blows at 130mph at TWS and the car makes a sharp right and heads for the wall. The wheel catches, digs in and rolls the car a couple of times HARD. The 968 roof structure is quite strong with its four layer construction, but it compresses 6 inches...
The rollover protection is for this worst case scenario. You may not be racing, but don't fool yourself you're going just as fast.
How's that for convincing? I don't want to sound harsh, but am just trying to make a point.
Joel Wahlsten
(This post was last modified: 07-23-2007, 10:15 PM by
JWahlsten.)
Threads: 14
I used to drive my car all the time with the fixed race seats in it. If you get tunnel mounts for the seat belts it's no big deal. I actually found them plenty comfortable.
The dual purpose seats are a great compromise in my opinion. Flash's seat are beautiful (saw them at Hershey), but you can get them much simpler and cheaper. I've had Konigs and thought they were very comfortable for daily use. I had them recovered, and had leather pads sewn into the bolsters to prevent the excessive wear on the outsides of the seats.
The only caution I have is I did see a 911 go backwards into the armco at the Glen in turn 10, and his Recaro SRD seatback broke. He was uninjured, but the fixed back is going to be slightly safer.
The seats are removed with two to three electrical connections and 6 bolts, so removal is an option.
To properly install belts you really should drill into the tunnel. I know Brey-Krause makes a kit for seat mounted harnesses though. The reason for drilling and installing a new mount is the geometry of the belt install to prevent dumping. Belt dumping is really what led to the basal skull fracture that killed Dale Earnhart Sr. You'll want separate mounting locations for you sub belts as well. These and the tunnel mount should be backed by 4" plates.
Joel Wahlsten
(This post was last modified: 07-27-2007, 04:11 PM by
JWahlsten.)
Threads: 14
Mike, thanks for the link to that thread. There is more good discussion there on the HANS/Isaac devices as well.
As far as the seats go, I haven't sat in the fighter, but have had both the Rev and Evo. The Evo was better, but I really didn't like the way the upper portion of the seat rolled my shoulders forward. I am an aging swimmer/cyclist as well so can relate to your body type. I will need to sit in whatever seat I am going to buy before purchasing to ensure comfort and hole placement for a head and neck restraint.
Don't think of just now. Think where you want to be in five years...Good advice advice from a friend who clubraced and owns a pretty darn good race prep shop in VA.
Joel Wahlsten
