Threads: 137
<img src="/forum/images/smilies/968/blink.gif" class="smilie" alt="" /> Anyone know about where on our temp guages a standard factory thermostat should be opening?
When it's 105 and your running your A/C and driving hard, does your temp gauge go up near the upper white mark?
Thanks in advance... <img src="/forum/images/smilies/968/rolleyes.gif" class="smilie" alt="" />
Michael Sorbera
aka San Antonio Silver Bullet
2002 VW Beetle TDI
2004 Nissan Titan Crew Cab
1990 Mercury Grand Marquis
Threads: 5
Regarding the second question, normal behavior is for the fans to kick on high just as the needle hits the top 10 oclock white mark which will cool the engine down close to the bottom mark. This cycle will repeat.
If AC is on the fans will be on full and even with the temp over 100F in Arkansas I do not see the gauge go far beyond 9:30.
If the gauge ever goes over the 10 oclock line something is wrong.
Threads: 137
Thanks for all the inputs - the guys at the shop think my thermostat may be opening late - does that sound about right? (the fans come on fine, and there is no leaks in the cooling system, 5 month old water pump)
They didn't put a new thermostat in January when they did the water pump <img src="/forum/images/smilies/968/sad.gif" class="smilie" alt="" />
Michael Sorbera
2002 VW Beetle TDI
Threads: 5
Rereading your posts I would try changing the thermostat. I would buy one for $20, then hit autozone for $15 of antifreeze, a heavy duty set of circlip pliers as well as borrowing a radiator pressure tester then change it myself.
This should take care of most of the possible problems (coolant, bubbles in cooland and thermostat) in one hit and cost you $50 and a Saturday morning. Instructions are online at
http://clarks-garage.com/shop-manual/cool-08.htm . The cirlcip is a real pain without the heavy duty tools but otherwise it is a pretty easy change.
Threads: 137
Yup, I've changed one before, I know the drill!
I think I'll tackle it this weekend...
Michael Sorbera
2002 VW Beetle TDI
