Threads: 35
I assume it's stamped on the block somewhere?
Greg
'92 cab. Guards Red/Black.
Threads: 35
If I'm checking for "matching numbers", what do I compare the windshield pillar VIN to? Located where?
Appreciate any help.
Greg
Greg
Threads: 167
I tried to research this a bit this morning. I don't believe that the VIN is on the block. Sorry, not sure how you tell if the car is "Numbers Matching".
Threads: 35
Thanks. I have no concern, but a potential buyer asked.
Greg
Threads: 9
The owner's manual says the engine number is on the rear-right of the crankcase, it's below the exhaust pipe for cylinder #4 on mine.
Michael
'95 968 Sport
'73 VW GT Beetle
Threads: 167
I saw that pic, but it's a 944.
Threads: 35
So, based on what az968 said above, finding the stamping on the engine doesn't necessarily tell me anything. I still have to get the certificate of authenticity. Looks like that would cost $85 from PCNA. Any other way to get that info?
Greg
Threads: 49
If you consider the logic in place here, that it is important for collector value to have the engine that matches the car, but there is no easily available record of which engine went in each car, the question therefore becomes moot.
Add to that the simple fact that there are very few of these cars around, and entire engine swaps would be statistically rare because the typical problem of valve piston collisions do not require replacing the engine, just rebuilding the head.
What you get should be a greater concern that the head is the original one, not the engine block, and that the whole issue is probably unimportant since the data to show if the engine is original are not realistically available.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Threads: 35
I'll take a look when I get home. At least I could see (without spending $) if it is from the correct year.
A prospective purchaser wants to buy and enter into Preservation Class events. Maybe you need a COA to prove all the major components are original. I have no experience with car shows.
Greg
Threads: 35
I'm still not seeing it. I have a D1R heat shield installed. Is it possibly obscured by that?
Greg
