Threads: 137
if the belts are still on, if you bring the camshaft to it's mark, then you can look at the flywheel and the marks will be obvious.
Most folks just line up the mark on the camshaft, put the flywheel lock in, and then do whatever needs to be done...I did it that way and all went well.
Michael Sorbera
aka San Antonio Silver Bullet
2002 VW Beetle TDI
2004 Nissan Titan Crew Cab
1990 Mercury Grand Marquis
Threads: 137
hmmm, I thought it was the other way around, two rotations of the crank to one of the cam?
If you're right, then how come when ever match up the cam markings, all the balance shafts line up also? Do they also do two per one revolution of the crank?
Another thought - why does it matter? If you line up the cam marks and lock the crankshaft, and replace the belts, what's the dif?
Inquiring minds want to know! <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" /> <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
Michael Sorbera
2002 VW Beetle TDI
Threads: 63
[quote name='kwikt' post='39872' date='Aug 13 2007, 06:04 PM']I changed the regulator today and it only shows 12.45 volts while idling and revving the engine doesn't change the volts either. So I'll probably order one tomorrow. Oh... and I finally got the thermostat snap ring off. Went over to the local Harbor Freight and picked up a set of assorted snap ring pliers($9 for the set of 6), one which happened to have a 90 degree bend, and no time flat ...out came the snap ring. It took me longer to jack the car up than to replace the thermostat!!!!!!Tomorrow new plug wires, cap, rotor and alternator. I hope that's it for now.
Kevin[/quote]
Kevin-
Just reading your post and hoping to contribute to the discussion. Sorry if you have moved on.
I had a similar problem with my '87 944 n/a. Car ran fine but I thought my alternator was going bad. Seemed like it would labor and the voltage would drop, according to the readings on my dash. I had the Princeton Porsche shop check this twice for me. (2nd time was no charge. Service manager was very cool.) They said that the alternator was fine, readings were good, and that it was probably just a "tired" diode.
Hope this helps.
-Scott
SOLD! 1992 - 968
Threads: 63
[quote name='kwikt' post='41607' date='Sep 23 2007, 04:59 PM']Well Scott, just finished replacing my alterator today. I checked the volts and it read 13.4 so I guess I sort of needed one. BTW I bought it at the local Advance Auto for $110 plus a $105 core if you keep your old one....not a bad price! Oh also.... I never could find the marks for TDC.
Kevin
72 911T/E
92 968
95 Yamaha PW50 (for sale)
01 HD Fatboy
03 330i
07 F150[/quote]
Kevin,
Cool. It is great when you can find the culprit. $110 is a great price, from Advance? That's a surprise.
Check the DIY's for a post on Balance Belt Replacement - let me see if I can get the link...
http://www.968forums.com/index.php?act=Att...e=post&id=1
I am right in the middle of doing my belts and rollers, and found the above very helpful. It's an
outstanding write-up on replacing balance and timing belts, rollers, etc., and it includes a description
of how to get TDC. It helps to have a friend do this with you - one looks while one cranks - saves time and helps to have another set of eyes to validate what you are seeing, especially if it is your first time doing this "fun" job.
Cheers and good luck!
-Scott
SOLD! 1992 - 968
Threads: 51
I went through this "where the hell is the tdc mark thing" and can tell ya it was all very confusing. The flywheel mark is viewed from the bottom of the car looking back from the front of the car. If you are under the car looking back at where the flywheel would be, there is a 3/4" plastic plug at the center front down low. Pull out the plug and shine in your light. There are 3 marks like "lll" and the center mark is the one used. When this mark is visable as well as the mark lining up on the cam gear and housing you are at TDC on #1. I stuck a long wire down the sparkplug hole to show me it was at the top of the stroke as well. Hope this helps as there are too many wrong locations discussed.
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
