Where can I put jackstands?
Where can I put jackstands if I'm using a floor jack on the jack points?????
(front and rear) pics if you got em please!!!
I got no pics, but normally I put a jackstand under the front control arm near the caster block or the engine cross member. On the rear, near a suspension component. When in doubt, look for a suspension component close to the area where it mounts to the body. These are the strongest points. Avoid sheetmetal unless it is the dedicated jack pads.
Thanks...
Because the 968 is a 50/50 car, you can jack at a front jack point, a jack plate helps and is more safe, and then put a jack stand on the rear jack point, or vice versa.
A while ago someone posted these pix on the other 968 forum and I saved for future ref. Let's see if I can put all them in 1 post.
Perfect! That's exactly what I was looking for!!!
[quote name='sheehanj' date='Jun 25 2005, 02:48 PM']A while ago someone posted these pix on the other 968 forum and I saved for future ref.  Let's see if I can put all them in 1 post.[/quote]
Yes, this is very helpful. Thanks!
It is difficult to see from the pictures, but if that big lump is a brick then run away fast. Never , ever use a brick or concrete block to support the weight of a vehicle, unless you want to commit suicide.
Using the jackstand a capella is the safest solution.
Quote:but if that big lump is a brick then run away fast
It appears to be a block of wood to me. I think I see grains in the larger picture.
I use the rear jack point for the floor jack, put jack stands under the front lift pads and put the rear jackstands under the torsion bar carrier, just outboard of the sway bar brackets. The torsion bar tube sits in the curve of the jackstand very nicely.
Eric
Here's a picture Bruce Ward posted on rennlist (I think) that has a great pic of the underside and jack points and alternate points:
[Image: JackingPoints.jpg]
I guess Rich Sandor should be credited as well <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
FYI, that picture is of a 944 turbo and the jack points are different from a 968.
Eric
[quote name='memphoman' date='Jun 28 2005, 02:22 PM']I guess Rich Sandor should be credited as well  <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
[right][post="6490"]<{POST_SNAPBACK}>[/post][/right][/quote]
Yep - Rich just got a '92 968 Coupe to keep his 951RS company....
