Threads: 16
Guys,
I autoX my 968 cab and run Victoracer tyres. I heard that they can be inverted to get more life out of them, in spite of the asymmetric thread. Any advice on when to do this - are there wear marks to look for? Also, do I run them until cords show up or is there other sign to replace?
BTW, thanks to advice from people on this net on pressure, alignment, etc., I got my second class win this season in a five-car PCA class, even beat a feather-light 914! Go 968!
1994 Iris Blue cab, Weltmeister chip, KLA brace, K&N, Victoracers, Odyssey battery, Iridium plugs
1989 944 Turbo, Victoracers, Odyssey battery, Fastest Time of Day at Metro NY autoX out of 60 cars
(This post was last modified: 05-04-2005, 10:34 PM by
Andre.)
Threads: 5
I've never autocrossed them, but I've run several sets of Victoracer V700's on the track. I always ran them until they showed a little bit of cord. Then its time to trash them. When you suspect they're getting close to cording make sure you inspect them after every session.
On the track my tires always wore the outside edges more than the insides, and I suspect with heavy autocross use yours will too. When the tread pattern is pretty much worn away on the outside, and you're afraid that the tires might cord soon, then its time to flip them on the rim. After filpping make sure to carefully inspect both the outsides and the insides.
Jim Child
'94 968 PCA E-Stock/NASA GTS2
'01 Boxster
Threads: 16
Jim,
Thanks! I will keep an eye on the cords and will flip them over just before they show up.
Andre
