Threads: 13
Wondering if anybody out there has added a hitch to their 968? I would like to add one to tow a small tire trailer. Is there a source for the hitch or will I have to get something custom fabricated? On 968.net, in the "Modifications" section of the website (not the Forum), there is a mod that Mike O'Leary / Rod Hill did that has some nice pictures but does not mention where the hitch came from.
Thanks,
mike
93 911 C2 Coupe
Threads: 13
[quote name='Jason Judd' date='Jan 6 2006, 09:42 AM']Mine was by a company called Southsport; I had their tire trailer, too.
[right][post="14247"]<{POST_SNAPBACK}>[/post][/right][/quote]
Thanks Jason...I wanted to go with the Southsport hitch and trailer but they are no longer in business.
mike
93 911 C2 Coupe
Threads: 13
[quote name='Anchorman' date='Jan 6 2006, 09:52 AM']There is also a factory setup. Check the PET. When I priced it, nearly 3 years ago (how time flies when you're having 968-fun), it was a bit over $1k. I think there were still a few available. I decided not to take that route for carrying my bike rack. Instead, I've gained weight.
[right][post="14249"]<{POST_SNAPBACK}>[/post][/right][/quote]
Over $1k...too pricey for me. Hopefully, I can find something cheaper. I was upset about paying $650 for my Touareg factory hitch. Thanks for the info.
mike
93 911 C2 Coupe
Threads: 31
Several of the S2000 guys I know have had custom hitches done for a few hundred bucks that look real nice. I'll see if I can find one of them are in Florida.
Threads: 8
Is towing even covered in the owners manual? I don't recall seeing it. I am heading down a similar path, so... inquiring minds want to know <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
HWFM Chief Marriage Counselor
Threads: 46
hey guys thanks for this thread, I may be doing this sometime in the future as I increase my bass rig. Also thinking about a roof rack. I appreciate the links and advice.
Sean - San Francisco
Threads: 46
[quote name='flash' date='Jan 23 2006, 10:46 AM']this is not terribly feasible
keep in mind that the max load of a hardtop is 639# and the cab is 397# - this INCLUDES passengers!
after deducting the weight of the people, then, deduct from the remainder, anything you are carrying inside the car, and any added components to the car (aftermarket amps, heavier wheels, etc) - also deduct from those numbers the wieght of the hitch itself
now you have what's left available to you for loading - you can figure in the tongue weight from there - my guess is that you won't end up with much available
u-haul definitely won't rent to you
[right][post="14951"]<{POST_SNAPBACK}>[/post][/right][/quote]
Thanks for the heads-up. I'll have to keep it all in perspective. . . I don't want to twist up my beautiful p-car. Good news is there are good lightweight options for bass with the new neodymium magnets. . . could probably do everything I need with 80 lbs, maybe even 60.
Threads: 46
I for one appreciate the help all around. It's all good fellas.
Threads: 6
I see this and a couple of other old posts about trailer hitches; none with links to a good solution (that I can find anyway). I've towed a tire trailer behind my 944S2 for years with no problems and now need to do the same with my 968. I was hoping there would be a way to pull off the bumperettes and buy (best case) or fabricate (worst case) something that would mount in place of the rubber.
Flash are you saying those aren't mounted directly to the bumper? (I agree that the hitch needs to be fastened to the bumper)
Any and all suggestions welcome at this point. My mechanic thought he had one lined up but apparently not.
TIA
Bill
1994 968 White Clubsport look, dual purpose street and track
