Thatks All. It sounds like something is rattling, a loose part, around clamp. With the car sitting in the garage I've hit the sunroof with my fist and hear it rattle. I've taken the sunroof out/off and shaken it but get no rattle and knock it with no rattle. I'll try that again. Then I've knocked the roof liner around the latch and get no rattle either but when I put back in, get the rattle. Maybe the latch isn't tight.
All the mechanisms work and align up correctly, and open and shut together. I've been though that drill already.
I'm sure the seals are all original but when closed is tight around the opeing and I dont have any water leaks. Knock on wood.
I did push up on the sunroof with the sunroof closed and got no rattle. Wonder if the plastic has "warped" alittle?
I'll keep working on it. Thanks
