Spherical Bearing Sizes
Anybody able to help out with the sizes or part numbers for replacement sperical bearings for the Racers Edge front a-arm bushes - both the front bush and the camber block?
I'd like to try and source locally and save the freight.
many thanks and Happy New Year
George
it isn't just the bearings, so i don't think that will help much
what isn't just the bearings?
I need to replace the spherical bearing as they are worn - little point in replacing the housings also.
Bearings are retained in the housing with a circlip, so a straightforward proposition to press out and replace.
have you tried removing the bearing and looking for a manufacturer part number (like a Timken number)?? http://timken.dirxion.com/
968Gene
ah - i thought you were just trying to replace the rubber with the bearings alone - my bad
i would grab some calipers and measure, and then order from a bearing company - i do that here from king bearing - no idea where down there though
Up here in the colonies (Canada) I buy FAG bearings for some items. There is a distributor in NZ.
(Unit R, Cain Commercial Centre)
20 Cain Road
1135 Penrose
New Zealand Tel. +64 9 583 1280
Tel. +64 021 324 247 (Call out fee applies)
Fax +64 9 583 1288
[Image: icon-goto_FAG.gif] sales.nz@schaeffler.com
thanks for that - I was hoping get the replacement bearings before I pulled everything down so would still appreciate sizes/ part no's if anyone has them.
