I just got the 1995 coupe back from the mechanic today after a long repair list was done. I originally took it in as the A/C compressor (new compressor and dryer) had cracked where the upper adjusting bolt went thru. As It cracked the A/C belt came off taking out a chunk of the upper radiator hose 94410623911 $83 as well as the power steering belt. Those were not the surprise repairs.
A power Steering tension rod had cracked and was fixed by welding it.
There was a sleeve missing to the power steering mount missing, fabricated a new one.
The cruise control was not working. It turned out to be a faulty The clutch pedal switch which was replaced 9446134300 $25
These cars are getting old.
