Threads: 69
I replaced all the wiring when I did the new starter on the Cab. Mine was crunchy and brittle too! Based on the condition of the underside of the Coupe, it can't be any better!
- Darryl
Threads: 77
Those wires are replaced and upgraded to much bettery quality in the Higher Connections cable kit. Their link is at the top in the Sponsors area.
(This post was last modified: 03-15-2010, 01:22 PM by
flash.)
Threads: 167
Last Spring before Hershey I did both a new starter and a Higher Connections kit. I have not had a single starting issue this year, even when the car sits for a couple of weeks.
Threads: 224
On a steep incline put it in 3rd.
Cant imagine the shock that would give. With the way my garage is situated it would ram the living room wall. I looked into the higher connections last year but didn't pull the trigger. Worth another look.
Threads: 30
Wow! Very scary.
When I was at RSB 2 weeks ago and Max pulled out the cable to the starter as part of my compression check, we saw that some of the insulation for the cable was coming off. A piece of electrical tape seemed to be adequate at the time, but I will definitely be looking at a new set of cables ASAP.
Jamie
Threads: 224
Is there a quick fix outside of pulling out and re running all the wires?
Perhaps some electrical tape to keep them in check till one could properly obtain the wire kit?
Threads: 167
That what Max did on my car. Seperated and wrapped the wires until my new starter could be installed. I would not reccomend this as a long term fix.
Threads: 77
(This post was last modified: 03-19-2010, 11:37 AM by
banditsc.)
Threads: 77
Check the insulation on the alternator wire also, you can get at it from the engine bay.
