Any experience with this company's product?
http://www.convertibletopguys.com/index.ph...tegory/view/772
I've read Flash's post denoting that Robbins is the original and "all others are replicas" , however one of their German Sonnenland canvas tops came with my car and would appreciate some feedback before spending a minimum of $500 to have it installed.
Thanks,
968kid
i have no experience with that company
but, just because a top isn't the original manufacturer doesn't mean that it can't work - GAHH makes a top that seems to have worked on a number of cars - the fit may be a little different, but i've seen them, and they go up and down and hold out the elements
the fabric on the one you show is the correct fabric- if they made the pattern from an original top, and then assembled it the same way, it should work fine
the problem you will likely have is not really related to the top, but rather the way most shops work - they don't like to have you bring your own top - they often say they won't warranty the installation
good luck
