Threads: 17
I just got my car about 10 months ago with vary little history so I really don't know if this car was converted to 134a refrigerant or not. Most probably not but it's worth a try. What does an R134a input fitting look like?
Also, if it does have R12, do I really have to replace ALL the seals?
Steve
Steve Patrick
92 968 Cab
76 912E Coupe
68 912 Targa
68 911 Coupe
78 Alfa Spider
62 Alfa 2600 Cab
Threads: 4
Only the '92's had R-12, 93 and on were all R-134 from the factory.
-John
'94 968 Iris Blue
'84 944 Gemini Grey (gone but not forgotten...)
Threads: 17
[quote name='jpk' post='39546' date='Aug 7 2007, 05:00 AM']Only the '92's had R-12, 93 and on were all R-134 from the factory.[/quote]
Mine is a 92
Steve Patrick
92 968 Cab
76 912E Coupe
68 912 Targa
68 911 Coupe
78 Alfa Spider
62 Alfa 2600 Cab
Threads: 51
If a conversion was done, a sticker should have been placed in the engine compartment stating so. I converted my 944S and the fitting looks pretty much the same only larger as I recall. My 968 was converted by the PO and it has the sticker.
Too bad the low side valve is in such a pain area or you could just get a shop to peek under and tell you. As it stands you have to have the car lifted and the plastic tray removed to get to it. No seals need to be replaced.
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
Threads: 17
[quote name='Ryan' post='39573' date='Aug 7 2007, 11:46 AM']If a conversion was done, a sticker should have been placed in the engine compartment stating so. I converted my 944S and the fitting looks pretty much the same only larger as I recall. My 968 was converted by the PO and it has the sticker.
Too bad the low side valve is in such a pain area or you could just get a shop to peek under and tell you. As it stands you have to have the car lifted and the plastic tray removed to get to it. No seals need to be replaced.[/quote]
Thanks Ryan,
I was hoping that (if I had to) it would be pretty simple to just do myself.
Steve
Steve Patrick
92 968 Cab
76 912E Coupe
68 912 Targa
68 911 Coupe
78 Alfa Spider
62 Alfa 2600 Cab
Threads: 17
[quote name='Richard' post='39602' date='Aug 7 2007, 07:45 PM']R12 as it is still readily available and only costs a little more than R134A.[/quote]
Where do you get R12?
Steve Patrick
92 968 Cab
76 912E Coupe
68 912 Targa
68 911 Coupe
78 Alfa Spider
62 Alfa 2600 Cab
