Threads: 9
Hi all,
Hope this is in the right spot, it seemed to make more sense in 'electrical' than 'interior'.
I need to pull my instrument cluster to replace the odometer drive gear (hopefully that's all it is!). From reading up it looks fairly straightforward, but is there anything I need to bear in mind beyond what's mentioned in the 944 workshop manual (couldn't find anything in the 968 manual)? I've a vague recollection of reading that the car needs to be left idling for ten minutes if the battery has been disconnected, so that the ECU can sort itself out again, but I can't seem to find this now - is that right? The car is a Sport, so doesn't have an airbag to worry about.
Thanks in advance, any advice appreciated <img src="/forum/images/smilies/968/smile.png" class="smilie" alt="" />
Michael
'95 968 Sport
'73 VW GT Beetle
Threads: 9
Thanks <img src="/forum/images/smilies/968/smile.png" class="smilie" alt="" />
Michael
'95 968 Sport
'73 VW GT Beetle
Threads: 8
1992, 968 Cab, Horizon Blue
Threads: 42
It's not too bad, you can do it without removing wheel, just a handful of screws. Be careful not to drop them down the air vent.
2005 Acura RL
2004 Toyota Sequoia
Threads: 9
Hi all,
Thanks for the advice <img src="/forum/images/smilies/968/smile.png" class="smilie" alt="" /> I pulled it all out today, cleaned out the debris, counted the teeth on the big gear and put it back together, apparently without incident (looking forward now to doing it all again when the new gears get here...!). Well, mostly without incident - it turns out there are at least two alarms on this car <img src="/forum/images/smilies/968/wacko.png" class="smilie" alt="" /> My heart sank when I reconnected the battery and heard a series of unfamiliar 'alarm arming' pips - fortunately, it turns out that the one fob disarms both alarms!
Michael
'95 968 Sport
'73 VW GT Beetle
Threads: 14
No fob unless the alarm is aftermarket. The alarm automatically arms when you lock the door.
Joel Wahlsten
Threads: 9
Sorry yes, my fob is for the aftermarket alarm. Whoever installed it thought about it properly though, as they rigged it to turn off the original Porsche 'siren' as well if it goes off, even if the aftermarket one itself isn't armed.
Michael
'95 968 Sport
'73 VW GT Beetle
