Oil filter wrench? -
Scott Collins - 02-14-2009
Hello everyone-
I am having trouble getting an oil filter off -that sucker is really on there...
- what size filter wrench do I need to remove an OE oil filter?
Thanks for the help! Cheers!
flash - 02-14-2009
i always use a "slip type" - it's a band that self tightens, and uses a ratchet extension and ratchet to drive it - this allows you to get down at the bottom where you get leverage - i've never been a fan of the kind that fit over the end - i always seem to bugger the filter up that way, and still not get it off
Yah, I hear you. I already have that one though, and I still can't budge it...
I either get the proper socket to fit over the top, or I just pop a screwdriver through it and twist.
I would prefer to have the proper socket, but just don't know the size.
flash - 02-14-2009
try tightening it first
xrad - 02-14-2009
try it when hot.
of course, don't get the oil on you...
Xrad-
I drained the oil out already and did not think the filter would be a problem - I guess I could heat it with a blow torch - I thought about that, but figured that head would cause expansion, which would only make it tougher to get off.
Flash - try tightening first, you mean to "wake it up"?
Thoughts?
flash - 02-14-2009
exactly - works quite a lot
SILVY968 - 02-14-2009
<!--quoteo(post=67047:date=Feb 14 2009, 12:19 PM:name=Scott Collins)-->QUOTE (Scott Collins @ Feb 14 2009, 12:19 PM)
<{POST_SNAPBACK}><!--quotec-->Yah, I hear you. I already have that one though, and I still can't budge it...
I would prefer to have the proper socket, but just don't know the size.<!--QuoteEnd--><!--QuoteEEnd-->
Scott,
I bought a socket for it before I changed to the canton. The socket says 76mm.
it's off...
xrad - 02-15-2009
Scott: heat softens the rubber seal...
Now when you put it back on, don't over-tighten like the last guy
flash - 02-15-2009
and oil the rubber seal first
gryphon - 02-15-2009
Scott, you gotta learn to control that temper. [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]
Tom
flash - 02-15-2009
of course, if you switch to the Canton filter, you won't ever have to do that again - many of us are running it, and LOVE it - absolutely zero issues after about 4 years - the old design had some snags a number of years ago, but the new one has been great
rs barn sells them
