Ruf goes green - Printable Version
+-- Forum: THE 968 FORUMS PUB (
https://968forums.com/forum/the-968-forums-pub)
+--- Forum: NON PORSCHE 968 RELATED DISCUSSIONS (
https://968forums.com/forum/non-porsche-968-related-discussions)
+--- Thread: Ruf goes green (
/ruf-goes-green.html)
Ruf goes green -
Fox944 - 03-06-2009
http://www.worldcarfans.com/90...eneva
<!--QuoteBegin-worldcarfans+-->QUOTE (worldcarfans)<!--QuoteEBegin-->Going green means different things to different people. For tuner RUF it means cleaner cars and in this case, cars also painted in green. RUF has developed the eRUF Greenster with Siemens Corporate Technology. The eRUF explores many of the themes being investigated by automakers such as fewer C02 emissions and electric propulsion.
Going further than that the eRUF does something quite new in that it is fitted with a bi-directional network connection that not only allows its battery to be recharged in less than an hour on a 400-volt power outlet but also lets the car return energy back into the power network if needed. The system is called eDrive.
The Greenster has a motor that pushes out 270kW (362hp) and stomping torque of 950Nm. This propels the 1,695kg (3,737 lbs) car from 0 - 100km/h in about 5 seconds reaching a top speed of 250km/h. RUF says using a bigger battery block top speed can be increased to 320km/h. When it is time to stop the 19-inch five-spoke wheels large ceramic brakes are on call.
RUF will start producing the eRUF in small series by 2010. The Greenster can be seen live at the 2009 Geneva Motor Show which is currently open until March 15, 2009.<!--QuoteEnd--><!--QuoteEEnd-->
reminds me of the old soft window targas
Ruf goes green -
S_Cal968 - 03-07-2009
Hmm, looks like the old British racing green which was thought to be unlucky. Overall I like the look - however I'd probably go with a black center wheel instead. Not much of a stick shifter...
