Clean your K&N filters - Printable Version
+---- Thread: Clean your K&N filters (/clean-your-k-n-filters.html)
Clean your K&N filters - rhudeboye - 03-08-2009
While washing the 68 today I popped the hood and gave the engine a wipe down. While under there I removed and cleaned the air filter using the K&N cleaner, let it soak for 10 -12 min then rinsed and let it dry. Now my car isn't a daily driver so by appearance the filter looked pretty clean, hardly anything inbetween the folds. However after putting it back in and taking it for a spin, it both sounded different and had more power. I also used the K&N oil on the filter before reinstalling it.
Not rocket science but thought I'd post my experience anyway for those that havent cleaned theres in a while. Go ahead and take care of it next chance you get, takes all of 20 minutes and is well worth it.
Clean your K&N filters - Anchorman - 03-08-2009
Thanks for this reminder - mine is definitely past due for its cleaning.
Clean your K&N filters - rhudeboye - 03-09-2009
<!--quoteo(post=68211:date=Mar 8 2009, 05:12 PM:name=Anchorman)-->QUOTE (Anchorman @ Mar 8 2009, 05:12 PM) <{POST_SNAPBACK}><!--quotec-->Thanks for this reminder - mine is definitely past due for its cleaning.<!--QuoteEnd--><!--QuoteEEnd-->
Yep, You wont regret it.
Clean your K&amp;N filters - 94SilverCab - 03-09-2009
On the list for my pre-Hershey prep... [img]style_emoticons/<#EMO_DIR#>/rolleyes.gif[/img]
Clean your K&amp;N filters - banditsc - 03-09-2009
Just don't over oil and only oil on the bottom side.
