Turning Brake Rotors - Printable Version
+---- Thread: Turning Brake Rotors (/turning-brake-rotors--9744.html)
Turning Brake Rotors - rkeysor - 04-01-2009
I think I once knew the answer to this, but is it permissable to turn the front rotors on 968s? If so, what would be the minimum thickness be? The last time I had this issue, on my 944, I simply replaced rotors and pads and called it a day.
Turning Brake Rotors - flash - 04-01-2009
minimum non-M030 front rotor thickness is 26.6mm
lateral runout of .05mm maximum
