Flooded wells - Printable Version
+--- Forum: WAX ON - WAX OFF (https://968forums.com/forum/wax-on-wax-off)
+--- Thread: Flooded wells (/flooded-wells.html)
Flooded wells - Gotter - 04-02-2009
Fall begets leaves, and I'm usually good about cleaning out the wells that collect water and debris from the crack between the hood and the windshield.
Usually.
We've had a crap-ton of rain, and I was out of town on business for 10 days during most of that rain... and now my passenger side floorboard is drenched.
So, clean out your leaves, guys and gals!
Now, to find someone with a Wet-Dry Vac... [img]style_emoticons/<#EMO_DIR#>/dry.gif[/img]
Flooded wells - 968gene - 04-02-2009
you may want to place one of these in the car for a few weeks.....
http://www.damprid.com/indexf671.html
Flooded wells - Gotter - 04-03-2009
Thanks, good idea!
Flooded wells - PorscheDude - 04-03-2009
Also this is a good time of year to remove all debris from the cowl area, clean all body drains to prevent moisture build up (cowl, doors, sunroof, etc.)
Flooded wells - Anchorman - 04-04-2009
I have a rainwater issue on the driver's side that I've never solved. When driving in reasonable to heavy rain, water will start dripping on my left foot, in the area of the foot rest. It must be coming in from someplace around the fuse box, but despite many searches, I've not found it. Most annoying.
Flooded wells - TheJoe - 04-09-2010
sorry to bring up an old post but i have the same issue in my cab with the water dripping on my left foot in rain or after i was the car
im going to try and find the reason myself
anyone else have this problem or any solutions?
Flooded wells - DaveN - 04-09-2010
For me it has always been the double sided tape that glues on the black plastic shroud at the bottom of the windshield; it tends to let go or warp. Both my 944 (not the S2) and 968 leaked in the footwell and sealing that joint fixed the problem.
